Trany durability
Old Oct 2, 2007 | 03:18 PM
pricja00's Avatar
pricja00
Default Trany durability
Have a 95 dually V10 with around 100k miles.... trany has been moaning in reverse... I've never worked it that hard... what's the history of Dodge trany's? ...do they generally need rebuilds after 100k? I was hoping I could get another 50k out of it b4 opening it up.
Old Oct 2, 2007 | 04:56 PM
2500 mopar's Avatar
2500 mopar
Default RE: Trany durability
yep dodge is, in my mind, known for their trannys......being horrible. i dont know if you need a rebuild yet but eventually it will maybe inone mile or a million miles i had my 2001 5.9L 4x4's tranny rebuilt and new transfer case all done at about 64,000 miles.
Old Oct 2, 2007 | 08:07 PM
rabbler's Avatar
rabbler
The reverse moaning is a pretty common problem. If that is your only problem you shouldn't require a rebuild.
There was a new heavy duty regulator valve released by Chrysler to fix this problem. It requires removing and partially disassembling the valve body to fix. There is a tsb covering the symptoms
