Bleeding fuel line
Old Oct 3, 2007 | 05:48 PM
echseman's Avatar
echseman
Default Bleeding fuel line
Ok, a quick question. I have to pull my injectors out, and need to bleed the fuel. Last time I did it, I had to wrap a towel around the line. I tried pulling my fuel system relay, but it ran for about half an hour, and the fuel pressusre was still @ op temp. Back to the question, if anyone has done it by pulling the relay, how long before your fuel line was empty? Thanks.
Old Oct 3, 2007 | 06:09 PM
steve05ram360's Avatar
steve05ram360
Default RE: Bleeding fuel line
when I pulled my fuel pump relay, there was no power to the pump, motor would die instantly...
edit: you might look for a fuel pump fuse... there should be something to cut power to the pump.
Old Oct 3, 2007 | 06:52 PM
rabbler's Avatar
rabbler
I think you pulled the wrong relay. Usually it should stall the engine in a few seconds. Does your truck have a fuel test port on the rail (It was stupid Dodge removed it on some years)? You could bleed the pressure off there.
Old Oct 3, 2007 | 08:12 PM
echseman's Avatar
echseman
yeah, i pull the right relay. maybe i will try the fuse. makes sence though. ha. the test valve was where i bled the pressure last time. i just didn't want rags soaked in gasoline.
Old Oct 3, 2007 | 10:13 PM
steve05ram360
if the relay is yanked, check the other side for power out to the pump, you may have a short. when you kick on the ignition do you hear the pump turn on, then off? (with the relay in)
Old Oct 3, 2007 | 10:47 PM
echseman's Avatar
echseman
ok, it worked this time. haha. don't know why it didn't last time. thanks steve05ram360 and rabbler. Just cleaned the injectors via sonic wash. cyclinder 5 is still missfiring. oh well. i will be pulling the engine soon anyways. thanks again guys!
Old Oct 3, 2007 | 11:01 PM
steve05ram360
do a compression test on it and see how it's doing. chances are you have cracked heads which is common. the mag heads crack between the valve seats. Hughes engines offers a HD head casting to replace them... fairly cheep (in comparison) at about $275 ea bare...
Old Oct 4, 2007 | 12:00 AM
rabbler's Avatar
rabbler
Did you put the injectors back in the same cylinder? If not try swapping #5 to a different cylinder and see if the miss moves to that cylinder. #5 plugged on mine but I was able to flush out the inlet screen with some carb cleaner. I just blasted it down the fuel inlet and all the rusty crud came out. It's been over a year and all is still good
