HELP!!!!
Old Oct 8, 2007 | 08:40 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Default HELP!!!!
Today I was pulling a heavy load 60 mph down a highway when my truck instantlyjust shut down. I tried a rolling start several times but could not start it untill I turned the ignition off, then back on. After that, it would shut off if Icame to a stop, and my speed sensor went dead for a while, then would come back on, only to go back off. I need a new cat, but doubt that was the culprit. So I suspect the fuel pump or the ECM...any help?
Old Oct 9, 2007 | 08:15 PM
johnnyrocket5363
Default RE: HELP!!!!
AWWWWW COME ON!!! Update: Truck runs OK for a few miles then loses power. It still shuts down at idle, but when I crank it back up, itidles fine.
Old Oct 9, 2007 | 08:17 PM
Bouncer88's Avatar
Bouncer88
What was it reading for RPMs when it first shut off?
Old Oct 9, 2007 | 08:57 PM
johnnyrocket5363
Around 2000 RPMs.. People say it's probably my fuel pump but I'm broker than my truck..Do they make fuel pumps with filters out side the tank? Or are the filtersdesigned to be efficient for 100,000+ miles?
Old Oct 9, 2007 | 08:59 PM
Bouncer88's Avatar
Bouncer88
As far as I know you need to buy the in tank fuel pump, and yes they are very expensive.
Old Oct 10, 2007 | 06:35 PM
johnnyrocket5363
Hmmmmm... I thought that, surely, out of all the people belonging to this site, some one could tell me the problem. UPDATE: Speedo still dead, truck behaving worse, and soon I'll be towing the 2.5 ton paperweight up the driveway unless the culprit is found. It will not idle after acceleration untill you crank it back. PLEASE!!!!!!!!
Old Oct 10, 2007 | 06:50 PM
motorbrreath's Avatar
motorbrreath
sounds like the fuel pump. its gonna run about 200 bucks.
specialist484's Avatar
specialist484
use you air pressure tool to read the fuel pressure at the fuel rail. You might have to cycle the key a couple times to build pressure. Im not sure the amount of pressure you should get but it should be above 30 I think. Did you check your codes? That would help. Cycle the key three times on/off and look at your digital milage display or enigne light lumination (count the flashes).
Old Oct 11, 2007 | 11:34 AM
johnnyrocket5363
It's throwing the p0500 code for a speed sensor malfunction, but that wouldn't starve the engine for fuel, would it? Plus, I can't even find the speed sensor on my tranny. The fuel pressure should be between 47 and 52 lb. but I have no gauge. UPDATE: Thats it! This overpriced stereo system is going to the mechanic; I'll let him agonize in frustration
Old Oct 11, 2007 | 03:56 PM
greenmachine's Avatar
greenmachine
Your speed sensor will be on the driver side tail of the trans.Take it out and wipe all the crud off of it. You will lose a little fluid.The speed sensor is a magnet, same concept as a cam or crank sensor. It is not that expensive if u just want to buy a new one to eliminate it as a possibility. If that dont work then ohm out the wire going from the sensor.
