NEED HELP!!! GEARS 4.10 or 4.56
Old Oct 18, 2007 | 07:13 PM
dodgenightpuma's Avatar
dodgenightpuma
Default NEED HELP!!! GEARS 4.10 or 4.56
i have an 01 1500 with the 5.2, six inch lift, and 35 inch bfg mud terrains and i need some help deciding on which gears to pick. The whole problem and why im doing the swap is i have no power at seventy and my speed just bleads off as soon as the overdrive kicks in and my shift times are all off due to the bigger tires causeing me to use WAY more fuel than i should! i have been told two different gear ratios and i dont know which would be better for my application 4.10 or 4.56. What are there differences and what are thereadvantages and disadvantages of both?PLEASE HELP!!
Old Oct 18, 2007 | 07:16 PM
2500 mopar's Avatar
2500 mopar
Default RE: NEED HELP!!! GEARS 4.10 or 4.56
i have 4.10's but my ride is stock everything,so i think that you should go with the 4.56's
Old Oct 18, 2007 | 08:03 PM
DurangoDarrin's Avatar
DurangoDarrin
I agree with Mopar....4.56's. With those tires it will be nice.
Old Oct 18, 2007 | 08:14 PM
dillonjm's Avatar
dillonjm
Yep, another vote for 4.56's. It'll be close to the stock power band. See this chart:
http://www.4lo.com/calc/geartable.htm
Old Oct 18, 2007 | 08:15 PM
rabbler's Avatar
rabbler
+1 for4:56
Old Oct 18, 2007 | 08:31 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Another vote for the 4.56 gears. I have 4.10's with 33" tires and I think that before I ever went for larger tires than 33's I would regear to maintain the power.
Old Oct 18, 2007 | 08:33 PM
aim4squirrels's Avatar
aim4squirrels
I currently have a stock truck as far as tires go with a 4.10 gearupgradeand I can tell you, this is the way the truck should have come! If you're running 35" you need to go 4.56 at least. You might want to think about 4.88's.Seriously give it some thought. 4.56's will put you back to close to stock, but stock already sucks, go smaller!
Old Oct 18, 2007 | 08:41 PM
dillonjm's Avatar
dillonjm
Can't get 4.88's in the 9.25 rear end. 4.56's is as low as it goes. One of two major downfalls of the axle. That and the c-clip shafts.
Old Oct 18, 2007 | 08:43 PM
dhvaughan's Avatar
dhvaughan
4.56 on 35's. 4.88 on 37+.
Old Oct 18, 2007 | 08:44 PM
Silver_Dodge's Avatar
Silver_Dodge
ORIGINAL: dillonjm
That's not true. You can get 4.88's in the 9.25.
I'd say 4.88 if you want mostly low end torque, or else 4.56 for all purpose driving.
