ignition coil and necessary parts for them
Old Oct 20, 2007 | 06:38 PM
2500 mopar's Avatar
2500 mopar
Default ignition coil and necessary parts for them
okay so now im looking for ignition coils and i guess you have to have wires and harnesses for them so who is selling them and for what price? thanks
Old Oct 20, 2007 | 11:46 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: ignition coil and necessary parts for them
Get an MSDblaster 2 or 3 coil. Also get an accel wire harness so you can splice into the accel harness rather thancutting up the stock coil adapterin caseyou ever needed to go back to stock. Shott wrote a DIY on installinga whole MSD ingition system that would have every step you need in one of the DIY sections at the top of the forum.
You can definitely find the coil for under $50 and that harness I think is under $10.
Old Oct 25, 2007 | 09:20 AM
2500 mopar's Avatar
2500 mopar
anything else?
Old Oct 25, 2007 | 10:03 AM
IndyRamMan's Avatar
IndyRamMan
I agree with the blaster 3. You need no adapter, just the coil. The coil wire is a female connection, and the blaster 3 is a male connector, it plugs right in. Cutting up the factory coil wire (talking about the 2 wires on the harness now) isnt that big of a deal, just get some ring connectors and cap the ends of the wires with them. If you wanted to go back to stock, just hold on to the harness you cut, and make sure you left about 2"-3" of wire so you can splice it back together if you ever needed it. As far as mounting goes, I went to home depot and got 2 3" ( i believe) pipe clamps. The pipe clamps I got had a hole in one part of it where you can mount it. The factory coil bolts worked just fine to attach the pipe clamps to the bracket. Check my photo album for the pic of what it looks like (its in the stock location)
https://dodgeforum.com/photo.asp?pho...=6&apage=1
I painted them the color of my truck because I thought copper looked trashey
Old Nov 4, 2007 | 08:59 PM
2500 mopar's Avatar
2500 mopar
couldnt find the DIY...
Old Nov 4, 2007 | 09:19 PM
2500 mopar's Avatar
2500 mopar
will this work = summitracing part number ACC-140021AH
along with the BLASTER 3 coil = MSD-8223
Old Nov 5, 2007 | 07:06 PM
2500 mopar's Avatar
2500 mopar
anyone?
Old Nov 5, 2007 | 07:36 PM
padodgeram's Avatar
padodgeram
ORIGINAL: 2500 mopar
MSD-8228 will work to no slicing or dicing the accel wiring harness ACC-140021AH
Old Nov 7, 2007 | 06:25 PM
2500 mopar's Avatar
2500 mopar
does anyone know what the stock ignition coils max voltage is?
Old Nov 7, 2007 | 07:16 PM
aim4squirrels
Steve told me once max voltage from the stock was 25K. The stock replacement coil from MSD (#8228) puts out 35K. I believe the turn ratio is 72:1.
The Blaster 2 and 3 coil (Blaster 3 is 8223) put out 45K and has a 100:1 turn ratio.
