Sqeaky and Sneaky
Has any of you ever had some sqeaky noise somewhere in the front end that you CANNOT find?!? I do, and I have lubed every freakin' thing that I can get to...nothing helps. I thought maybe its a generic thing that someone else has experienced. Anyone know what I mean??? Is it just me??? Drives me f'n nuts!!![:@]
I've got one in the front to. It dosen't coincide with the engine speed. I can hear it at a stop and it gets worse on a bumpy road. I suspect that it is the idle arm. You might look there for yours to.
ORIGINAL: ICEMAN_CH
Alright guys, here's the deal so far. I took the lithium grease and sprayed every joint in the front susp that I could, and also the steering column...I sprayed the hell out of it. Took her for a test drive, couple miles, making sure to hit every single bump I could while driving slow. Guess what...NO SQUEAK!!! So far... Hope it lasts... Thanks to everyone for their advice and comments. To those with the same problem, get you a can (or two) of white lithium grease and go to town.[&:]
P.S.-Forgot to add that I also sprayed the crap out of that horizontal arm from the tranny.
