Compression is bad :(
Old Oct 30, 2007 | 09:15 PM
mikerados21's Avatar
mikerados21
Default Compression is bad :(
Got my truck back and he told me the compression test was dramatically bad..
Kinda like this.....
Looks like to put a new motor... O well ill never give up on her..!!!!
Old Oct 30, 2007 | 11:56 PM
Socha_62's Avatar
Socha_62
Default RE: Compression is bad :(
I wouldn't believe him. Don't take the opinion of one shop or one person. Or just do a compression test your self.
Go to AutoZone and rent a comp. tester. Pull the fuel pump relay then take one plug at a time out and screw the tester in. Crank it 3 revolutions and take the reading. Put that plug back and do all the others. Should be at least 95psi, also all the cylinders should be really close to the same psi.
If you pay thaty guy to put a new motor in and don't get a second opinion or don't do it yourself your screwing yourself.
Old Oct 31, 2007 | 01:10 AM
rabbler's Avatar
rabbler
Could be just a cracked valve or seat. A valve job is a lot cheaper than a new engine. I would ask to see the test results. These guys sound like jackasses [sm=icon_beat.gif]
How many miles on your engine?
The shop didn't really give you that pic did they?
Old Oct 31, 2007 | 08:10 AM
aim4squirrels's Avatar
aim4squirrels
I wouldn't trust that test, looks like the mechanic let his 4 year old daughter do it and taught her some choice language.
It's relatively easy to do yourself as Socha described, then you know your results.
Old Oct 31, 2007 | 07:09 PM
Socha_62's Avatar
Socha_62
Then if the test is bad it could easliy be the valves as said above.
