ticking noise while driving
Old Nov 1, 2007 | 09:27 AM
ONECRAZYJEEP's Avatar
ONECRAZYJEEP
Default ticking noise while driving
i have recently have been hearing a ticking noise under my truck like you tied a wire to yourdriveshaft and let it hit something as it spins. it only tings when im moving. its not the motor i know that for sure. any help would be nice.
rearend?
tranny?
idk. thanks in advance.
Old Nov 1, 2007 | 09:43 AM
JAKD RAM's Avatar
JAKD RAM
Default RE: ticking noise while driving
My brother in Laws GMC Sierra does that. It just recently started happening after he got his duel exhaust redone at Meineke. I have no idea what it is but it sounds EXACTLY the same as you described it. If you find out what it is let me know so I can pass on the info to him.
Old Nov 1, 2007 | 10:06 AM
bill022572's Avatar
bill022572
U-joints - maybe ?
Old Nov 1, 2007 | 10:33 AM
mopar crazy's Avatar
mopar crazy
Does it get louder the faster you go or is the noise the same pitch? At what speed do you notice the sound......slow, fast, or acombination? Does it make the noise when your at idle and you rev the engine? ( in case its a loose exhaust hanger).
Old Nov 2, 2007 | 09:30 AM
ONECRAZYJEEP
it only makes noise while moving. i noticed it doing about 30 but it is doing it right when i start until i come to a stop. and it has the same pitch. its not like a squek its a ticking noise. in my jeep the u jopints went bad i know what that sounds like and it is completely different. ill look a little more tinight and let you all know. thanks for the help so far.
Old Nov 2, 2007 | 09:57 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Makes me think it could be an injector.
Old Nov 2, 2007 | 09:59 AM
ONECRAZYJEEP
but wouldnt that send off a code?
Old Nov 2, 2007 | 10:39 AM
JAKD RAM's Avatar
JAKD RAM
My brother in laws almost sounds like someting is sparking. Maybe a wire is pushed up against a pipe an it melted or something?
Old Nov 2, 2007 | 11:59 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: ONECRAZYJEEP
No. Sometimes a sticking injector will 'tick'.
ORIGINAL: JAKD RAM
Dammit, I should have thought of that. Been there before although it was a broken connection inside of the spark plug boot. Intermittant contact caused the ticking and arcing.
Old Nov 2, 2007 | 01:17 PM
SilverRam_01's Avatar
SilverRam_01
ORIGINAL: JAKD RAM
IDK about the GMC, but didn't Jeep say it only happened when he was going, not when he was idling, I think if something was arcing, it would be doing it idling as well. Same pitch too, he says, what about something in the tranny thats ticking when it goes into gear?
