Please Help..... And Hi BTW....
RE: Please Help..... And Hi BTW....
This one as well...
http://dodgeram.org/tech/gas/Trouble/Problems.htm
scroll down to:
Spark Knock, engine miss, hesitation, rough idle, surge, delayed shifting, etc
scroll down to:
check plenum gasket.
a good amount of them will only act up when the truck gets hot/warm because the oil that is stitting in the intake is thicker when cold and when it is heated up, the oil thins out and gets sucked into random cylinders.
it can also set a rich code.
Do compression test, check/change cap + rotor
and check plenum
engine off, remove air box, open throttle plate, using flashlight - look down into intake for oil inside.
DIY info is at top of main 2nd gen Ram page
and check plenum
