1997 1500 5.9 2WD LIFTED TRANNY PROBLEM
Old Nov 2, 2007 | 12:55 AM
dwnlowx's Avatar
dwnlowx
Default 1997 1500 5.9 2WD LIFTED TRANNY PROBLEM
I HAVE A 1997 1500 RAM WITH A 5.9 EXTENDED CAB IT IS 2 WD LIFTED
MY CHECK ENGINE LIGHT KEEPS COMING ON
THE CODE IS PO740
THE BOOK SAYS TOURQUE CONVERTER CLUTCH CIRCUIT MALFUNCTION
HAS ANY BODY HAD THIS PROBLEM BEFORE
THE TRUCK RUNS PERFECT BUT WHEN I CHANGED THE TRANNY FLUID I NOTICED IT SMELLED LIKE SOMETHING WAS WRONG OR BURNT
I HAVE ABOUT 115000 MILES ON THE TRUCK
ANY INFO HELPS THANKS
Old Nov 2, 2007 | 05:38 PM
Ramafication's Avatar
Ramafication
Default RE: 1997 1500 5.9 2WD LIFTED TRANNY PROBLEM
what size are your tires?, if they are much larger than stock,it causes a load on thetranny having to spin the rear end, also make sure the cooling lines are not clogged up for the transmission cooler.
Old Nov 3, 2007 | 09:10 PM
dwnlowx's Avatar
dwnlowx
33 INCH TIRES AND A BODY LIFT
