lift kit with spacers
Old Nov 3, 2007 | 12:56 PM
jfantastik60's Avatar
jfantastik60
Default lift kit with spacers
hey guys, i already have a 2.5" superlift kit on my truck but i want to go higher but i have a budget so i was wondering what if i put those 2.5" coil spacers up front keeping the superlift coils and shocks and then took out the superlift leaf spring in the back and bought a 5" to match the front.. you think i would have to switch my shocks?
Old Nov 3, 2007 | 12:58 PM
tdmopar59's Avatar
tdmopar59
Default RE: lift kit with spacers
for a 5 inch lift you would need a lot more than new shocks... thats why the kits are so expensive you gotta get shocks, track bar drop kit, sway bar relocating kit, and a lot more...
Old Nov 3, 2007 | 02:10 PM
padodgeram's Avatar
padodgeram
thats right , need a track bar drop bracket , pitman arm , swaybar drop bracket , shocks , rear will be add a leaf , or new springs , or another block (not stacking ) . now if you did not do this you can do a body lift 3" be a little cheaper then you would have a 5.5 " lift.
Old Nov 4, 2007 | 12:50 AM
spaz_22's Avatar
spaz_22
you also need new control arms as well
Old Nov 4, 2007 | 01:13 AM
nhlbill's Avatar
nhlbill
You will definetely need longer shocks to go from a 2.5" lift to a 5" lift.
That said, max lift on stock control arms is 3", so your going to need new control arms. Most reputable lift companies also relocate the upper control arm in their 5" kits to address proper geometry too, so just longer control arms is not a good solution either.
You will also need a trackbar drop bracket, a new pitman arm, longer bump stops, a couple of brackets to drop suff like the front brake hoses, rear brake hose, e-brake cable, and smog canister, and oh yeah longer shocks.
3" is where everything is inexspensive and easy, 5" is where everything gets much more exspensive and much more complicated to do safely. If you really want 5" of lift you have a couple choices:
1- Add a 3" body lift to 2.5" suspension lift (cheapest route....about $300.00)
2- Buy a 5" suspension lift kit and take your 2.5" kit off and sell it. (plan on a grand difference)
Old Nov 4, 2007 | 12:28 PM
jfantastik60
wow thanks alot i completly forgot about the pitman arm and everything.. this was just a real quick thought i had while i was one DF ....haha tht coulda been bad if i just went and did it with out asking
