tire size question
Old Nov 3, 2007 | 08:52 PM
Magnumpwr16's Avatar
Magnumpwr16
Default tire size question
this might be a dumb question, but if i were to keep my stock 16" rims, whats the biggest tire size i can put on there, as far as like off-roading tires.........
Old Nov 3, 2007 | 08:56 PM
BadHab1t's Avatar
BadHab1t
Default RE: tire size question
there are 50 million threads about this topic do a search or just scroll thru the pages ull find hundreds ....j
Old Nov 3, 2007 | 10:25 PM
Cereal Killer's Avatar
Cereal Killer
The only real limiting factor (besidesbackspacing) is the width. it's only 7 inches wide. I've never seen anyone put a tire fatter than 12.5 inches on it, and I'd say that's pushing it. 285s are probably the widest you should go with it.
Old Nov 3, 2007 | 10:36 PM
padodgeram's Avatar
padodgeram
285 is the height .. 70 or 75 is the width.... i had a 35x10.5 on my stock rim 16x7... of course i have a lift...
Old Nov 3, 2007 | 10:52 PM
Cereal Killer
No man, 285 is the width of the tire in millimeters which is almost exaclty 11". The second number 75 in this case is a percentage (in this case 75% of 285) and that determines how tall the tire is. 3rd numbers is the wheel size but I know you know that
Old Nov 3, 2007 | 11:05 PM
jonnyv713's Avatar
jonnyv713
but what if u have a dually anyone have any suggestions for that
Old Nov 4, 2007 | 01:00 AM
nhlbill's Avatar
nhlbill
Most tire shops will recommend against putting a 12.50 on a 7" rim and will suggest an 11.50 instead.
It doesn't matter how many wheels you have, it matters how wide the wheel is. Not sure on the duallies how wide their stock wheels are, but when your talking dually, your probably going to want to make sure the tire you pick stays within the recommended load rating for the truck, rather than how big of a tire. That way the truck can be used safely for what it was made for which is towing/hauling.
Old Nov 4, 2007 | 09:31 AM
padodgeram's Avatar
padodgeram
ORIGINAL: Cereal Killer
after reading this AM ... i was wrong.. your right..
Old Nov 4, 2007 | 09:56 AM
brndodge's Avatar
brndodge
I run 285/75/16 on my ram just like yours with no problem at all. I have wondered if I could go to a 315 though but that is pushing I would say.
Kevin.
