Thinking on buying a ram but i need help
Old Nov 5, 2007 | 09:19 PM
bwboley's Avatar
bwboley
Default Thinking on buying a ram but i need help
Ok I live ing portland Oregon im heading down to topeka kansas because my mom was killed in a car accident and so im going down there to buy a truck to bring a trailer back with some stuff back in a 14x8 wells cargo trailer. Well ive alwas wanted a dodge ram 4x4 after my mom had one it was a 95 ex cab 4x4 with a 360. Well i found one that i like its a 2000 dodge ram extended cab with the 2 suiced back doors, power windows locks and keyless entry 5.2 liter auto lifted 6" with 37x13.50x16 its priced at 7500 but i was trying my hardest to find this but in a 360 or diesel in that price rang and im looking for a truck in the kansas ok missoruri nebraska areas. So whats the differnts in the 318 vs 360 besides size and power?
Thxs Brad
Old Nov 5, 2007 | 10:22 PM
THEGOLDPRO's Avatar
THEGOLDPRO
Default RE: Thinking on buying a ram but i need help
the engines are nearly identical, the 5.9 has like 30 more tq, then the 5.2 litre which surprisengly makes a big diffrence as far as towing goes. i suspect if you try and tow a 14 foot enclosed trailor loaded up with the 5.2 litre with oversized tires its going to be a total dog on even the slighest hills. also take a look on this website it tells all about the engines.
http://dodgeram.org/tech/gas/specs/index.html
Old Nov 14, 2007 | 12:12 PM
bwboley's Avatar
bwboley
So what do you think of this one? i guess i can put some work into a 318 to make i better or i can just get a 5.9L later and swap it in? http://kansascity.craigslist.org/car/476081867.html
bwboley's Avatar
bwboley
Old Nov 14, 2007 | 01:59 PM
IndyRamMan's Avatar
IndyRamMan
good luck getting through the mountians with that trailer. my suggestion would be to hold out for a 360 or cummins if at all possible.
Old Nov 14, 2007 | 02:30 PM
EricCartman's Avatar
EricCartman
I'm sorry to hear about your Mom...
If you can - ask what the gear ratio is. I suspect with 37" tire, the gear ratio had to be changed... or it would be a serious dog. I would guess the gearing is probably to 4.56. If the truck has gears that low... you might be OK...
Cartman
Old Nov 14, 2007 | 04:34 PM
bwboley's Avatar
bwboley
the gears are 4.56:1 Gears front and rear whats the :1 mean? and it has 5 ich lift and35 inch tiresheres the truck look here for more info
Old Nov 14, 2007 | 04:45 PM
tazman6789's Avatar
tazman6789
Thats a sharp looking truck... price a lil steep tho. got my 2000 ram 1500 sport 4x4 with 96k miles 5.9 for6500 not an extended cab but i wouldnt look for a truck cause it has a lift kit on it, and other bolt on parts.thats something you can add to the truck down the road when your not towing a large trailer. I like my 5.9 never drove the 5.2 so i cant say what i would wrather have. My truck came with a 3 inch lift, tires and rims already on, with an exhast too so that price a bit high for that old with that many miles in my opinion
Old Nov 14, 2007 | 05:35 PM
EricCartman
4.56:1 means the pinion gear turns 4.56 times for 1 turn ofthe ring gear. It's always expressed as some number compared to 1.
Cartman
Old Nov 15, 2007 | 12:56 PM
bwboley's Avatar
bwboley
All the trucks around this area is aroundthat much that has no rust and looks good the trailer isnt all the big but i want a ex cab 4x4 but il keep looking im also willing to go 250 miles from Topeka if anyone kno of one being sold
