Ball Joint Emergency
Old Nov 9, 2007 | 02:38 PM
kowboydmac's Avatar
kowboydmac
Default Ball Joint Emergency
I had my truck checked out at Tire Kingdom, and it turns out it needs over 1900 in repairs, mainly 1200 in ball joints and tie rods.
I need to know of any DIY writeups that I could do in my front yard that may help correct or at least stall this problem until I can find a cheaper place or save the funds to complete the job.
Thanks for any and all info.
The truck is
1996 Dodge Ram Extended Cab, 5.9L 360
16" Rims with 265/70/r16 tires
Old Nov 9, 2007 | 02:42 PM
BradBeyer's Avatar
BradBeyer
Default RE: Ball Joint Emergency
What year make etc..
Ball joints are not that bad to do.
Old Nov 9, 2007 | 02:48 PM
kowboydmac's Avatar
kowboydmac
ORIGINAL: BradBeyer
I figure it looks worse than it actually is, but alas it is something I have yet to do.
Old Nov 9, 2007 | 03:10 PM
BradBeyer's Avatar
BradBeyer
you can go to oriely's and get 4 ball joints for $150 - $200 and then your time
Old Nov 9, 2007 | 03:38 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: kowboydmac
The truck is
2WD or 4WD? That makes a big difference.
Old Nov 9, 2007 | 03:47 PM
kowboydmac's Avatar
kowboydmac
2WD. forgot to mention that. I know I can find the joints, I was just hoping there would be a writeup with some pictures on here.
Old Nov 9, 2007 | 04:16 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Spend the money and get a Haynes as it will pay for itself. Be aware that the ball-joint press from the FLAPS can be tricky to use. When I did mine I had to have my neighbor make a custom cup and the ones with the kit were either too large or too small. I spent most of a Saturday and Sunday on the job, but that was better than paying $1,200 for someone else to do it.
Old Nov 9, 2007 | 04:43 PM
kowboydmac's Avatar
kowboydmac
I have a haynes, lol. I'm just hoping someone has done this already and could give me some pointers.
Old Nov 9, 2007 | 04:47 PM
xtremewlr's Avatar
xtremewlr
This is for a 4x4 but a 2wd is essentially the same - dodgetalk.com/forums/showthread.php?t=178091
Ok, this is stupid. Why doesn't dodge talk show in that URL? Some kind of DF/DT animosity or something?
Old Nov 11, 2007 | 08:07 PM
kowboydmac's Avatar
kowboydmac
I service grade ball joints off of rockauto, hopefully they'll last a year or two until I redo the front suspension when i get shocks, coils, etc. I also got the jack and stands so hopefully with that writeup you sent, and my haynes manual I will be done by friday.
