Front Air Dam Removal?
What would it hurt if I took my front air dam off? I washed my truck today and I noticed a hellacious dent in it. I hit an armadillo the other day, but I didn't think nothing of it. I think that's where the dent came from. I don't think it would hurt anything, but I figured I would check with yall before I went to taking it off.Thanks.
RE: Front Air Dam Removal?
it could considerably effect your gas mileage in a negative way..... because these trucks are known for its great gas mileage lol
seriously though. it prolly wont do much damage to anything. im taken mine off as soon as i get a day off. looks like crap.
just my 2 cents.
just my 2 cents.
Yeah these trucks get great mileage. No matter what I do I can't do any better than 13. That's just the way it is when you drive a truck. But I'm not complaining, I love my truck. I don't think it would be that big of a deal if I took it off. I was just wondering if anybody else here had done it.
Trending Topics
old post from 4/23/2001
(if I were to repeat this test today I would try to do it with two Ram pickups and swap which one had the air dam on the second test. I have also tested using 'garden lawn edging' black plastic to extend the air dam downward another 2 inches...and also fitted small Wheeler style vortex generators to the bottom of the stock air dam temporarily with Scotch Super Strong auto trim double sided tape:
both mods made the Ram feel more stable at high speed
but in a careful highway test the little wheeler vortex generators hurt MPG by about 1.
I got frustrated today after getting word that a governmental decision I was
waiting for would not be forthcoming - despite being promised an answer for
the last two weeks.
In order to blow off steam,
and not end up with a completely wasted day,
I decided to try to find an answer to that urgent question weighing on the
minds of all mankind:
Does that Air Dam under the front bumper of a Ram do any good ?
I gathered up some music I hadn't listened to yet, and drove over to the
Clayton NC exit of I-40 just to the east of Raleigh and filled up with Exxon
87 octane. ($1.55 per gallon here)
I then drove in a loop trip down I-40 to Wilmington NC and back. The distance
was 218.7 miles. I started around 10 am when the temperature was about 73F.
There was a light wind from the south, which opposed my East by Southeast
route - at least on the first leg.
I drove a steady 70 mph with the cruise control set, and had the air
conditioner on with the temp control at the 11 o'clock position. Traffic was
light and I only had to take the cruise off 3-4 times on the trips.
I did drive by a forest fire just off the interstate though - complete with a
helicopter overhead with a underslung bucket that sprinkled water drops on my
windshield as I whizzed by without delay.
On the first trip with the air dam still on,
I used 11.53 gallons according to the gas pump,
which for 218.4 miles by the Ram's corrected odometer gave me a MPG of 18.94
miles per gallon.
I also reset the Oztrip computer and checked with it too during the trip. At
the end it said I used 11.60 gallons over 218.7 miles for an Oztrip estimated
MPG with the air dam on of 18.85
I then removed the air dam in the gas station parking lot.
If you do this be sure to spray WD-40 on the upper threads of the T-25 Torx
heead screws first. I first tried to remove them without the WD-40 and
stripped the first one - which then took 15 minutes to remove using a
vice-grip on the exposed threads inside the bumper. I thought Torx were
supposed to be strip-resistant ? With the WD-40 soak, all the rest came out
easy in less than 5 minutes. There are also two plastic rivets on the outside
edges (why Dodge, why not just two more torx's ?)
The second trip started around 2pm.
The temperature had gone up to about 80 degrees. Without the air dam the
Oztrip immediately showed less mpg at the steady 70 mph. I also felt I could
hear more wind noise - it seemed to come from the driver's side wheelwell
direction. Later I also thought the coolant temperature gauge was about 5
degrees higher at about 185 - but that might be due to the higher air
temperature outside.
Without the air dam, the Exxon gas station pump said I used 11.969 gallons
over 218.4 miles for an MPG of 18.25
The Oztrip computer estimated I used 11.99 gallons over 218.7 miles for an
estimated MPG of 18.24
So it looks like removing the air dam cost me 0.7 MPG at a steady highway
speed of 70 mph.
I guess two valid questions about a test like this would be:
1. "How much would two identical back-to-back trip MPG's differ by just
natural variation? "
2. Could anything else have caused the MPG difference ?
I do not know the exact answer to the first one - but based on the other test
runs I have done in the past I would guess natural variation would be
something like 0.2 to 0.5 mpg.
On the second question,
I imagine that varying wind speed might be a hidden cause. The cross wind from
the south did hurt the southeast bound leg of the trip, and help the northwest
bound leg - I could see this on the Oztrip meter. I would guess this wind was
about 10 mph.
It is also possible that the slight increase in air temperature made the air
conditioner work harder ( I personally doubt this) or perhaps the 7 degree F
hotter intake air made the engine slightly less efficient (the engine
textbooks mention this, but it is a very small effect).
I had hoped this test would have turned out the other way.
One reason I decided to do it was that a poster on the turbodieselregister.com
website had said that he had gained 1 mpg after taking his air dam off, then
lost 1 mpg when he put it back on later.
http://www.turbodieselregister.com/u...ML/000903.html
http://www.turbodieselregister.com/u...ML/001147.html
I was hoping to find another trick to gain some mpg, under the theory that
maybe the air dam was there only to reduce front end lift at high speed.
There is a book called 'Race Car Aerodynamics' that has a graph from a Society
of Automotive Engineers SAE paper that shows that air dams up to about 4
inches high slightly help in reducing aero drag.
Since the Ram's air dam is just about 4 inches too - I guess it does aid in
reducing aero drag after all.
the last two weeks.
miles per gallon.
speed of 70 mph.
about 10 mph.
I didn't notice any problems with the truck today driving to school. Everything seems just the same as when I had the air dam on. I did notice that my hood started shaking when I went to pass. I guess I was going about 75-80. I've never noticed that before. I don't know if I did something washing the truck the other day or if it's because I took the front air dam off. Mabye when I took it off it let a lot more air build up in the engine bay and that's putting extra pressure on the hood. I really don't want it to go flying up one day while I'm going down the highway. What do yall think?
