what does a pcm flash do?
Old Nov 15, 2007 | 09:28 AM
ONECRAZYJEEP's Avatar
ONECRAZYJEEP
Default what does a pcm flash do?
what does this pcm flash do for your truck? thanks for any info.
Old Nov 15, 2007 | 10:17 AM
padodgeram's Avatar
padodgeram
Default RE: what does a pcm flash do?
depends? dealer flash ? hypertech ?..
all it does is update your software in your PCM... today im gonna flash mine for my tires so i can get the speedo correct and the shift points..
Old Nov 15, 2007 | 07:06 PM
tazme695's Avatar
tazme695
The latest flash i just had done to mine : improved shift points delayed lock up til 53mph and fixed a serge between 3-4 you can ask your dealer for the update for (beaming) its 69.00 - 89.00 Hope this helps
Old Nov 15, 2007 | 08:26 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
A flash changes the PROM (Programmable Read-Only Memory) in the PCM.
Old Nov 15, 2007 | 09:21 PM
aim4squirrels's Avatar
aim4squirrels
ORIGINAL: tazme695
Do you havethe codingnumber for this particular flash? Just curious as to how "new" this flash is.
Old Nov 19, 2007 | 09:34 AM
ONECRAZYJEEP
i was wondering exactly what it dod because my truck shifts funny into 2nd and i also have bigger tires on it and my speedo is off about 1 mileper hour for every 10 mph i go so example it says im doing 50 but im really doing 55. so i need that fixed. will it help that?
thnaks
Old Nov 19, 2007 | 04:13 PM
LPIdaho's Avatar
LPIdaho
bump
Old Nov 19, 2007 | 08:47 PM
Sixtysixdeuce
ORIGINAL: ONECRAZYJEEP
thnaks
Don't need a PCM flash for that. Go to your local repair shops until you find a mechanic with either a Snap-on scanner or DRB III and offer him $20 to calibrate your pinion factor. He should be able to do it in about 5 minutes.
