trans filter bolt size?
Old Nov 15, 2007 | 12:15 PM
blazeplacid's Avatar
blazeplacid
Default trans filter bolt size?
Im hoping to find out what size the head is on the bolt that holds trans filter?
Ive done it before but forgot what size.
I think it was a t-27??
are theree any other wierd bolt sizes I need to worry about?
Its a V6
Old Nov 15, 2007 | 08:50 PM
dhvaughan's Avatar
dhvaughan
Default RE: trans filter bolt size?
i know its a torx, but i don't remember if its a 25, 27, or 30.
nothing wierd for pan and filter change. pan bolts are probably 13 mm
i think the band adjustment is a wierd tool. also takes a inch pound torque, or the experience to do it by feel. since i don't really know what i'm doing, i always just leave my bands alone.
Old Nov 15, 2007 | 09:46 PM
aim4squirrels's Avatar
aim4squirrels
The bolts holding my pan on are 1/2". 13mm works but in my experience, if you use the socket that fit the most snugly, you reduce the possibility of rounding them off. Mytranny filter bolts area #25 torx and they are pretty darn long. I suggest a 6" extension for your socket wrench(es)as it makes it easierto lay on the ground or dollyand not have to hold you arms up as high.
They make a nice little Stanley Torx socket set I got at Walmartthat has 11differentsockets in the 1/4" and 3/8" drive varieties.That'll cover just about every torx bolt you have on the truck.
That weird bolt on the tranny band is like an octagonalsocket and I can't even begin to tell you what size it is. I think you pretty much have to get it from the dealership parts counter.
