axle gearing!?
Old Nov 21, 2007 | 06:18 AM
HankL's Avatar
HankL
Default RE: axle gearing!?
Check to see if the torque converter lockup clutch is still functioning.
Run a stopwatch timed test past 10 mile posts are exactly 60 mph on the speedo to see if the calibration of the speedometer and odometer is correct.
Each ten seconds fast or slow of exactly 10 minutes is 1 mph off.
Old Nov 21, 2007 | 10:44 AM
ryans590's Avatar
ryans590
easier way to check the spedo is to use a gps if you or a buddy of yours has one
