Awesome tug of war vid-Ram vs F 650
Old Nov 20, 2007 | 05:38 PM
  #21
slored360's Avatar
slored360
Default RE: Awesome tug of war vid-Ram vs F 650
they said it was a 650 and they didnt use a chain, it was a 4- 5 inch wide tow strap. that was crazy.
Old Nov 20, 2007 | 06:42 PM
  #22
EricCartman's Avatar
EricCartman
If the chain broke... it should just drop in place (unlike winch cable or tow straps. )
Cartman
Old Nov 20, 2007 | 06:56 PM
  #23
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: slored360
truf it was. i didnt see the giant front fenders and the big rig mirrors.
Old Nov 20, 2007 | 06:57 PM
  #24
G0tMudd's Avatar
G0tMudd
ORIGINAL: EricCartman
Cartman
ur retarted, chains are very bad, they can snap and kill some1 easly, brake windows like nothing. Yes tow straps can still have alot of power, but nothing like chains. Chains are just out right drangirous
Old Nov 20, 2007 | 07:30 PM
  #25
Sixtysixdeuce's Avatar
Sixtysixdeuce
Might be a dumb question but what are rocks? Is that a manufacturer of axles or a figure of speech?
This is my M35A2 2.5 ton (deuce and a half) with standard equipment Rockwells. They are 6.72:1.
Keep in mind, those 9.00R20 NDT tires are 40" tall.
Old Nov 20, 2007 | 07:44 PM
  #26
Socha_62's Avatar
Socha_62
Chains are not *suppose* to be bad when they break but they are...Reason being they're not (again) *suppose* to store energy, meaning they don't stretch. Just like a winch line, but they do.
Just for the record I never use a chain, its always tow straps.
I've seen a winch line break though, it has quite a bit of recoil but not as much as I thought. You would defenately be hurting if it hit you though. It just shot back and hit the back of the truck and front of the Jeep. Didn't break any windows or even dent either one.
Old Mar 19, 2008 | 10:46 PM
  #27
98DodgeRam1500's Avatar
98DodgeRam1500
ORIGINAL: lucas3397
This is an awesome tug-o-war video I found on Myspace vidsbetween a Ramand a F-650. Ram keeps coming up into a wheeliefrom drag slicks and what looks to be a bad pull angle.
http://vidsearch.myspace.com/index.c...ideoid=5896031
Very bad pull angle for the ford. its taking all the weight off the back of the ford.
What an ugly beasty buldging ram.
I use a chain, I tend to break the nylon straps. my last pro-comp looked like a rubber band snapping. I am in the market again for another 15' 20,000lb (non-elastic) strap. I use the chain to pull fallentrees from the woods and straps for applications where a chain would destroy whatever i am pulling. This weekend i snapped my pro-comp on a meduim sized bush, it wentabout 10' backbut notfast enough to kill or even dent the truck, the nylon was weakend by an oldknot that i could never get out.
I know I would never use a cable... those i have seen snap and its scary.
Old Mar 19, 2008 | 11:06 PM
  #28
Cereal Killer's Avatar
Cereal Killer
I got some 20 ft nylon straps rated at 35,000 lbs and they've done right by me. I don't try to pull f650s or anything, but I've pulled some trees out and my buddies trucks out no problem.
Old Mar 20, 2008 | 12:17 AM
  #29
tresvn's Avatar
tresvn
hopefully he won a few dollars so he can get a new headlight bulb. and take his sister out to micky d's before he sleeps with her
Old Mar 20, 2008 | 05:28 AM
  #30
pipeking's Avatar
pipeking
the dodge had soft race tires slight advantage and/w rocks low gaers, def prolly could have done it i 2wd.also i think pinion axles are illegle cuz there could be a mech faliure between the brakes and tires when they could b directly bolted onto the wheel(stock).
i just love tug of war. also what is wrong with a chain?
