anyone ever fixed intermittent wipers?
Old Nov 19, 2007 | 10:38 PM
1980blackfiveoh's Avatar
1980blackfiveoh
Default anyone ever fixed intermittent wipers?
My wiper delay doesn't work so the wipers go the same speed regardless where the dial is on the intermittent setting. So they end up going at about half speed as the low setting. Has anyone one ever changed the controler and know where the relayis? It is starting to bug me so I think I'll try and fix it if I can.
Old Nov 19, 2007 | 10:41 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: anyone ever fixed intermittent wipers?
To future searchers: I said somethingdumb and was wrong,continue scrolling down for possible answers.
Old Nov 19, 2007 | 11:17 PM
dhvaughan's Avatar
dhvaughan
nope - not on wiper motor. i can't say for sure about your 99, but i can tell you everything about my 01's intermittent wipers. the twist **** on the multi-function switch is a variable resistor, wired to the Central Timing Module (CTM), which in my 01 is to the right of the gas pedal, under the dash and sort of behind the ash tray. mine was a black box about 4 x 3 x 1" thick. the CTM controls all timing related functions and also contains the chimer thing (ding ding ding). it cost $119 so don't screw it up. the wiper motor on my 01 is just a dumb motor with 4 wires (hi speed, low, park circuit, and ground).
I'll bet you $5 your have a blown or missing fuse in the end of your dash in the power window or power door lock slot. mine had that and the wipers would do the intermittent wipe about every 1-2 sec no matter where you set the dial. let me know if thats not it. there is a test procedure for the twist dial on the wiper switch in the haynes manual, but you have to take it off to test it. by the way it only costs $42 at autozone.
Old Nov 20, 2007 | 12:03 AM
ryans590's Avatar
ryans590
gee ill bet you have fixed it before dhvaughanlol
he is 100% right...nothing more to add lol
Old Nov 20, 2007 | 05:29 AM
shott8283's Avatar
shott8283
yea,.,, same problem with mine as wellk,,,, mine started to act up ever since i blew the I.O.D. fuze in the dash
Old Nov 20, 2007 | 07:43 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: ryans590
yes. after spending 2 or 3 weeks taking half the truck apart, replacing multifunction switch ($42), CTM ($119), relays ($5), testing everything, almost letting stealer parts counter convince me there was a control module on wiper motor assy ($120), pulling wiper motor off to prove them wrong, talking to dodge tech, studying wiring diagram over and over, testing, probing, testing - i finally gave up. there were no shorts or open circuits and nothing wrong that i could identfy and nothing further to replace. the worst part of it all was that I (repeat I) was the one that removed the power windows fuse because it turned off the "key in ignition dinger" and i thought i was so clever.. well, it also turned off a key element of the intermittent wiper circuit which lives inside the ctm with the dinger.
ps. the proper way to turn off the key in ignition dinger is to remove the clam shell covers from the column and unplug the 2 wire connector on the ignition switch. don't just rip the speaker off the ctm board or you will loose all chimes including low fuel, headlight on.
i have no experience with the IOD fuse. not sure how that would tie in. check all the fuses in the end of the dash before you waste a lot of money like i did.
Old Nov 20, 2007 | 09:11 AM
Obiejuankinobie's Avatar
Obiejuankinobie
Dhvaughn, your right the ding, ding, ding, ding, ding, is annoying. How ever after reading your post I think I'll live with it thanx for sharing your experience.
Old Nov 20, 2007 | 08:33 PM
1980blackfiveoh
nope fuses all look good.I also located the black box under the dash.... maybe I'll get on from the wrecker if the price is right.
