List of maintance to be done soon.
Old Nov 22, 2007 | 09:37 PM
05DodgeRamHemi's Avatar
05DodgeRamHemi
Default RE: List of maintance to be done soon.
hah yeah, by the time igot down there id prob. sent mroe gas than worth it lol
Old Nov 22, 2007 | 09:47 PM
xskylinedx's Avatar
xskylinedx
ORIGINAL: Sirhilton17
I wanna find one of the persons who owned my truck before me... so I can kick the **** out of them...
+1 [sm=icon_rock.gif]
I'm just glad I've had a little exta money so I can try to fix the neglect.
Old Nov 22, 2007 | 10:42 PM
Socha_62's Avatar
Socha_62
You guys actually charge labor at school? Ours didn't and we worked on tons of "customer" vehicles. Alignments are stupid easy though, especially since you only have to do the front, and since camber is factory set the only things to adjust are caster and toe!
Old Nov 22, 2007 | 10:43 PM
jnellydodge's Avatar
jnellydodge
LOL
Old Nov 23, 2007 | 01:57 AM
Cereal Killer's Avatar
Cereal Killer
Make sure you get yourself a tow strap so someone can come pull you and your all-terrains out
Old Nov 23, 2007 | 04:47 PM
05DodgeRamHemi
lol yeah no **** huh?! im sure theyll do fine though. im not a crazy offroad guy, so i need a tire that is better than average but is meant for the road mostly
Old Nov 23, 2007 | 06:20 PM
ICEMAN_CH's Avatar
ICEMAN_CH
While you are doing the trany you should adjust the bands.
Old Nov 23, 2007 | 07:04 PM
05DodgeRamHemi
Sorry I don't know what ya mean by that? Also, by adjusting the bands, what would that do for the transmission?? Thanks!
Old Nov 23, 2007 | 07:07 PM
2500 mopar's Avatar
2500 mopar
the bands are what give the tranny a tighter shift i think but im not sure... but you should always adjust the bands every trans. fluid change. They are adjusted by a bolt and nut just loosen and tighten, how much depends on your tranny model.
Old Nov 23, 2007 | 07:14 PM
Sirhilton17's Avatar
Sirhilton17
As the bands wear in the trannys, they get more sloppy... right... and you need to adjust them so they grab right... I dont know how else to say it...
When they are adjusted right u usually will get firmer shifts and what not... I think these trannys are supposed to have them adjusted every 30,000 miles... Most people never adjust them... Alot of ford trannys mostly the newer ones dont have adjustable bands... I know for a fact the e40d'd dont, and im fairly sure their new ones dont either... (another reason fords are ****...) If you leave a worn tranny band in there and use it, it will wear its self out faster. and on these trannys its kinda common for when they get loose that one of the band struts will fall off or somthing...
I dont remmebr exactly how many miles urs has, but i think u said its around 110,000 and ill tell you if its never had it done... it needs it... Mine has 90k and it has never been done and I know mine could use it also...
Im doing mine soon... actually I might do them tomaorw depending on the weather... its not hard.
