belt tensioner
Old Nov 24, 2007 | 09:26 PM
ryans590's Avatar
ryans590
Default belt tensioner
ok ive got kind of a dumb question....
ok thebelt tentioneris supposed to be spring loaded right, not one of the ones where you half to pull it back then tighten a bolt to hold it there....i have been noticing my belt starting to squeal when i start up the truck or turn sharp so figured it was time for a new belt, went to put it on but when i put my wrench onto the idler to remove the tension it just stayed wherever i moved it too (if i loosen it off it would stay loose or if i tightened it against the belt it would stay tight) so i figure its time for a new idler assy, jut just wanna double check that it is supposed to be spring loaded
Old Nov 24, 2007 | 09:34 PM
mopar98's Avatar
mopar98
Default RE: belt tensioner
uhhh yeah I'd be changing that tensioner real quick.
As far as I can remember they are always under load .
They shouldn't just move and stay back , they should spring forward aginst the belt.
Old Nov 24, 2007 | 09:38 PM
aim4squirrels's Avatar
aim4squirrels
+1
It's spring loaded.
There's a write up on it in Steve's DIY section if you want to read thru it.
Old Nov 24, 2007 | 10:18 PM
ryans590's Avatar
ryans590
yah thats what i thought, guess ill pick one up monday
Old Nov 24, 2007 | 10:29 PM
rabbler's Avatar
rabbler
Yours is seizing up. Common failure
Don't try and take it apart
Old Nov 24, 2007 | 11:53 PM
XXL 1500's Avatar
XXL 1500
ORIGINAL: rabbler
or else you may sustain serious bodily harm.
haha
Old Nov 24, 2007 | 11:55 PM
ryans590's Avatar
ryans590
haha i didebt plan on taking it apart, thought of spraying some WD-40 or something but ill just throw a new one in next weekend
Old Nov 25, 2007 | 03:31 PM
WayneC's Avatar
WayneC
You mention the "idler pulley" but are describing the "tensioner". Are you sure you're on the right one? The idler does NOT move to adjust the belt.
Just a thought.
WC
Old Nov 25, 2007 | 03:34 PM
ryans590's Avatar
ryans590
ORIGINAL: WayneC
Just a thought.
WC
my bad im talking about the tentioner....
