steering arm, control arm and track arms
Old Nov 27, 2007 | 10:07 PM
sabbath1994's Avatar
sabbath1994
Default steering arm, control arm and track arms
do i need new steerin arms, control arms, and track arms for a 4 inch lift???
this is my plan for the lift
4in skyjacker with 35's under the truck.
and if i need to do any other mods. please post.. thanks
Old Nov 27, 2007 | 10:11 PM
padodgeram's Avatar
padodgeram
Default RE: steering arm, control arm and track arms
anything after 5" of lift need to make changes drop pitman arm , drop swaybar bracket , control arms , but sky jacker only has a 3" or 5" or7" lift ..with the 3"lift kit comes with springs , lower control arms , rear AAL.. need shocks
Old Nov 27, 2007 | 10:30 PM
sabbath1994
no i made a kit
i order 5 inch lift springs that compress to 4 inch, and 4 inch leaf springs from skyjacker.. i got the 4-5 inch shocks for the front and rear
Old Nov 28, 2007 | 12:06 AM
junior's Avatar
junior
im pretty sure your going to need more than that.like trackrod relocation brackets, upper and lower control arms and sway bar brackets. correct me if im wrong and if i am im sorry, but im pretty sure thats right.
Old Nov 28, 2007 | 12:14 AM
sabbath1994
i have no idea thats why im asking
Old Nov 28, 2007 | 03:25 AM
Chopper1's Avatar
Chopper1
You will need several more items.....Look at the parts in these lift kits and most of the parts you will need. Most can be purchased seperately. Several on the site have gotten stuff from Top gun customz. http://www.marketworks.com/storefron...mp;i=126671366
http://rockymountainsusp.com/dodge4_94_01gas.htm
http://www.topguncustomz.com/
http://www.roughcountry.com/dodge_4wd_94-01_5.htm
An example of items, Track bar relocation bracket,Sway bar extention, Lower and upper arms. http://www.marketworks.com/storefron...amp;i=64085866
Old Dec 1, 2007 | 06:52 PM
sabbath1994
do i need a new track bar or just a track bar bracket?
Old Dec 1, 2007 | 09:15 PM
dsertdog56's Avatar
dsertdog56
You should get a different trackbar, but it should be adjustable like aThuren bar. It makes it easy to center your axle. This isbecause you are lifting the truck an odd amount. Brackets are more "lift specific". When I had discussed this with Don at Thuren he recommended a 5 inch bar, which requires welding.
Maybe trail master would sell you a T-bar. To my knowledge they are the only ones really offering a 4 inch lift.
You will need longer arms, and either sway bar brackets or longer links. I used 3 inch lift control arms with a spacer and off-roadster springs forjustover 4 inches of lift in the front.I adapted a set of XJ links from warrior products. I used 5 inch bumpstops which work fine.I'm not familiar with brakelines on an earlier Ram but mine were plenty long.
5 inches is the magicnumber...things become more complicated when you exceed it.
Old Feb 20, 2008 | 01:54 PM
Dewey1087's Avatar
Dewey1087
You don't have to get a new track bar. Just the brackets will to the trick. But anything over 3' you will have to go with the whole set up. Don't forget longer shocks too.
Old Feb 20, 2008 | 09:10 PM
swirvin21's Avatar
swirvin21
Thuren or DT ProFab tracbar....asked this question in another post, but trying to get more feedback. I'm leaning to DT right now.
Input appreciated... https://dodgeforum.com/m_1187038/tm.htm
[align=left] [/align][/align]
