trans compatability?
Old Dec 3, 2007 | 04:17 PM
inflictor's Avatar
inflictor
Default trans compatability?
i have a 98 ram 1500 w/ a 5.2
just bought a replacment trans , what came out was a 46re
the business i got it from gave me a 47re and told me there is no real difference,
once it was installed only drives in second and reverse and wont go into park
is there a difference in the two mechanically or electrically all the harness plugs seem to be the same but the bellhousing dust cover i had doesnt work on the 47re
are the two interchangable or not?
thanks for any info you can offer![:@]
Old Dec 3, 2007 | 06:12 PM
Midnight95's Avatar
Midnight95
Default RE: trans compatability?
i know from past experience i have had to have a ecu or pcm that goes with that transmission- its like if you take out a 5.9 and put in a 5.2 you have to change the copmuters too
Old Dec 3, 2007 | 07:07 PM
94ram360's Avatar
94ram360
it need s to hve the correct computer, otherwise you will stay stuck in limp mode.
Old Dec 3, 2007 | 07:30 PM
02cummins's Avatar
02cummins
some of you older guys might have the same problem
Old Dec 4, 2007 | 01:28 AM
Socha_62's Avatar
Socha_62
The second number is the duty raiting, so 47RE is suppose to be a bit beefier then a 46RE.
Old Dec 4, 2007 | 08:35 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Locate an ECM for that engine/tranny/year combination and you should no longer have the issue.
Old Dec 4, 2007 | 09:58 AM
master tech's Avatar
master tech
Site Moderator & Tech
The 47RE trans is for a diesel truck, This trans will not work. The torque converter has 6 bolts to hold the converter.
