4x4 question
Old Dec 4, 2007 | 02:41 PM
motorbrreath's Avatar
motorbrreath
Default 4x4 question
anyone know where i can find a diagram of the 4x4 system? my hanes manuel says nothin about it and im tryin to figure out why it wont engage fully.
Old Dec 4, 2007 | 03:14 PM
ramit2001's Avatar
ramit2001
Default RE: 4x4 question
Yeah mine has some troubles engaging from time to time. It is like it I have to pull it back just right for it to engage.
Old Dec 4, 2007 | 03:48 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Is it the transfercase not engaging or the axle?
Old Dec 4, 2007 | 03:54 PM
hkspwrsche's Avatar
hkspwrsche
There is a xmas thread that you might search for and a google search will turn up some articles
Old Dec 4, 2007 | 04:43 PM
zique's Avatar
zique
The diaphram itself cannot be purchased. You have to either find an old CAD at a junkyard and pull it apart, buy the whole CAD new, or replace it with a cable actuated posi-lok.
Old Dec 5, 2007 | 12:12 AM
motorbrreath
its soundin like its tryin to engage but it wont all the way. i need to get up under there tommrow and try to fix it, i just dont know where to start
Old Dec 5, 2007 | 12:13 AM
motorbrreath
ORIGINAL: zique
nah not diaphram, diagram. like a map out of the 4x4 system so i can know what im lookin at.
Old Dec 5, 2007 | 09:34 AM
WesV's Avatar
WesV
There ain't much to map out.
Transfer Case - Big thing behind the transmission with 2 drive shafts coming out of it and a shifter linkage up top going into it via 2 rails.
Front axle- Very simple due to full time wheel to axle engagement (AKA no locking hubs). You have a vacuum line running to your CAD and that should be all you have to worry about without a major axle tear down.
Basically we need to answer Ice_Man's question, what isn't engaging, the t-case or the front axle? If you can pull your lever all the way back and feel it hit a little detent, then the t-case should be enaged. Are you hearing gears grind or what?
Edit: If it weren't snowing here, I would crawl under my truck and take some pics and label themfor you, but sorry, I ain'tlaying down in the snow before class...
Old Dec 5, 2007 | 10:39 AM
ron333's Avatar
ron333
If you go with the posi-lock as zique mentioned, here's a link I found that I have bookmarked for when I get mine fixed. With all of the problems with the vacuum lines that I've found on mine, I am not even going to worry about whether or not my 11 year old vacuum actuator on my front axle is still working properly since I can't really determine that until I replace all of the missing / damaged and plugged vacuum lines. I don't really need the 4wd so this project is on the back burner for now. Here's the link:
http://www.strippermotorsports.com/4x4pofraxacp.html
Old Dec 5, 2007 | 11:57 AM
zique's Avatar
zique
ORIGINAL: motorbrreath
haha...sorry, I coulda swore that said diaphram when I first read it. There is a diagram on here somewhere. Do a search for CAD on here and it will come up. At least I found it when I was looking into a posi-lok earlier this year.
