will a cold air intake increase you mpg? & a few other ?'s
Old Dec 6, 2007 | 12:47 AM
Cereal Killer's Avatar
Cereal Killer
Default RE: will a cold air intake increase you mpg? & a few other ?'s
ORIGINAL: SilverRam_01
ORIGINAL: tdmopar59
y not do the round filter? i had that on my second gen and found it to be the best for performance... as stated before your not really gonna see much in mpg no matter what you use....
Wouldn't the round filter be sucking in hot ait off the top of the motor? Wouldn't that decrease performance?
Not really. There's so much airflow through the giant grills on or trucks, and all kinds of air comes in from underneath the truck. The air on top of the motor isn't THAT much hotter than it would be 6 inches from the motor.
Old Dec 6, 2007 | 12:53 AM
SilverRam_01's Avatar
SilverRam_01
Oh okay. That actually makes alot of sense. The air on top actually probably would be colder than the air right next to the manifold, where some of those 'other' CAIs pu the filter.
Old Dec 6, 2007 | 01:12 AM
padodgeram's Avatar
padodgeram
KN # 57-1503-1 is a open A/C and 50 state legal... i think ill ditch my CAI and go with the A/C since every one likes how they work but im gonna take some measures and maybe fit a 4-6" tall KN filter on it.. then ill be getting a cowl hood that only makes sense
Old Dec 6, 2007 | 01:27 AM
Cereal Killer
I'm going to be doing a 3" body lift instead of going full suspension specifically because of that. and if you get the cowl hood you could possibly even fit a taller filter in there. A functional scoop could onlybenefit this kind of setup as well.
Old Dec 6, 2007 | 04:00 AM
petekf4qoe's Avatar
petekf4qoe
Hey thanks for all of the input guys. I think the round ac is what I am going to do along with the headers and exhaust. I will post when I get it done and let you know what results I get. It will probably be after christmas before I get it done though.
Old Dec 6, 2007 | 06:36 AM
HankL's Avatar
HankL
If you think that aftermarket air filter improve MPG
or if you have read dozens of times about how dirty air filters hurt MPG
on modern EFI engines,
it will be well worth your time
to pick up the January issue of Hot Rod magazine
and read the 'Pit Stop' section.
The Pit Stop section is where long time engine builder Marlan Davis
answers technical and parts questions readers send in.
In the January issue
Marlan Davis admits that he incorrectly answered a previous question,
and he calls in an expert friend of his from 'EFI University' who specializes in
electronic fuel injection conversion of older muscle cars.
http://www.efi101.com/
All three of these guys with extensive experience and expertise
end up agreeing
that air filters...either clean or dirty....
have very little MPG effect on modern engines
and that dirty air filters cause a vehicle to act similar
to when the weather air pressure changes
or
when the vehicle climbs up to a higher altitude.
It is a sign of Marlan Davis' commitment to truth
that he admitted that he answered the previous question imperfectly
and that he publicly corrected the answer when challenged by an alert reader from Canada.
Marlan Davis could have just 'buried' the mistake
but he did not. Kudos to him!
Old Dec 6, 2007 | 07:09 PM
1BigRamaniac's Avatar
1BigRamaniac
Well, at the very least, it will be easier to change than the stock air cleaner. My 95 is a pain. I do not know if they fixed this after 95, but I have to do a little song and dance to align it all up.
Make sure you get a cool decal for it!
Old Dec 6, 2007 | 09:17 PM
ryans590's Avatar
ryans590
ORIGINAL: HankL
hahaha takes canuck to pick up on it eh lol.....sorry but i had tochuckle when i read that part
Old Dec 7, 2007 | 12:26 PM
Ole Goat's Avatar
Ole Goat
In reading all the replies to these different types of Air Filters, I have a question. I am considering buying one of these bolt on Cold Air Filters, "K&N" type for 2 reasons. First off is the power increase, second the MPG.
I'm past the stage where acceration off the line is an issue. I'm more interested in the 2 benefits that these "K&N" filters offer, or lay claim to. I pull a tandem car trailer, and do a lot of driving. As some of you know pulling a trailer in O/D, isn't a good idea. I run most of the time on cruise where or when possible, and depending on the wind direction MPG is an issue. I have a 94 Ram 1500 Magnum 5.2. This Truck has supprised the hell out of me, as I was always a Ford owner. My ford days as far as a daily driver ended with the 89 F-250 I had, a bad piece of junk.
I needed a Truck and the Ram was available and I bought it. This Truck pulls better than my Ford did and with better MPG. So ending my History of 2 different Trucks.
I am interested in knowing if the "K&N", Cold Air Filter, will improvethe performance of my Ram, in both MPG, and HP. I am baseing this on my driving habits, asI have mentioned above. Looking for an answer to this and what should I expect in these areas. I put on around the 20,000 miles yearly, thanks in advance.
Old Dec 7, 2007 | 12:38 PM
padodgeram's Avatar
padodgeram
just doing the filter alone as in stock replacment then no you wont see a thing , if you want to spend some cheese on a CAI then its kinda worth it..my self im running the Airaid cold air intake and it did help but i also have the exhaust , ignition ... 1 mod helps the other. Mr silver is running the open elm air cleaner as others are to and my self (soon) with great reviews.. but to get the full use out of it you gotta do other mods .. if you did other mods great !!! , go for the open elm. round AC.
