changing trans fluid
Old Dec 6, 2007 | 11:24 AM
bobbos_ram's Avatar
bobbos_ram
Default changing trans fluid
hey yall i was wanting to know if the middle plate ( atleast thats what i think it is but it really looks more like a gasket to me) is supposed to stay on the pan when i put it back together. i didnt think about buying a book before i started to change the fluid because ive done it in other vehicles with no problem and now i have no way to go buy one. but thats my question is the middle part the gasket dodge uses or is it like a cushion plate that needs to go back on there.
Old Dec 6, 2007 | 11:37 AM
bobbos_ram's Avatar
bobbos_ram
Default RE: changing trans fluid
i think i answered my own question cuz the filter kit came with two gaskets but one has a different bolt pattern
Old Dec 6, 2007 | 11:41 AM
plafleursr's Avatar
plafleursr
Yes, use correct fluid, I used AFT+4 by Valvoline.
Old Dec 6, 2007 | 11:58 AM
bobbos_ram's Avatar
bobbos_ram
yea i picked up valvoline atf4 last nite i could only find 5 quarts tho i read some where that sometimes it takes 5 but at times 7 to refill it so hopefully its only 5. and as the gasket goes on the pan i just read it says to reuse the reusable gasket but the gasket doesnt look to reusuable it really looks like a piece of plastic with rubber o ring type layout in it and a whole bunch of silicone on both sides.
Old Dec 6, 2007 | 12:06 PM
Cereal Killer's Avatar
Cereal Killer
scape all that **** off the pan, and around where it bolts up with a putty knife. Don't use a knife or a screwdriver cause you'll **** it up an it will leak. I'd use RVT sealant around the new gasket too if I were you. Unless it's some kind of rubber one. I woulnd't even use one of those.
Old Dec 6, 2007 | 03:05 PM
SilverRam_01's Avatar
SilverRam_01
I just did my tranny filter and stuff not that long ago, and I thought I was F**ked when i opened the box... there were three gaskets, and none of them were right, until I realized I had been holding the right one upside down, but yeah, I threw that piece of crap gasket thing that was on there away, put a little orange RTV around the gasket to hold it in place while I put the pan back up, and then ended up spending a fortune on Valvoline +4. Trannys loving me now though, more so than it did before.
Old Dec 6, 2007 | 06:56 PM
1BigRamaniac's Avatar
1BigRamaniac
Remember to torque the filter screws to 35 inch lbs., and the pan bolts to 150 inch lbs (17 Nm).
Old Dec 6, 2007 | 09:11 PM
ryans590's Avatar
ryans590
here is a DIY i did up on it a while back https://dodgeforum.com/m_901049/tm.htm
there is 2 gaskets because it is the same filter as a jeep but a jeep has a different pan, hence the different bolt pattern
Old Dec 9, 2007 | 05:22 PM
bobbos_ram's Avatar
bobbos_ram
wow 150 pounds thats more that lugnuts is that right well anyways i changed it used the rubber one from the kit and some silicone seemed all good then sat morn i parked in my drive way which is at a desent slant and after a couple hours had some oil on the ground so crawled under there to check it out and tighten some bolts well none of em were loose but i did tighten em some more and the leak got worse then just by wipeing where the oil was coming from i guess i some how moved the gasket and it started streaming out so i dropped the pan again cleaned the hell outta everyting and used the reuseable gasket and haveing had any problems yet knock on wood lol but yea are the bolts really supposed to be 150 pounds cuz its cast and really do not want to strip anything out
Old Dec 9, 2007 | 05:23 PM
bobbos_ram's Avatar
bobbos_ram
haha nevermind (inch pounds) i missed that
