MSD 6a spark plug gap and rough idle
Old Dec 7, 2007 | 08:18 PM
WayneC's Avatar
WayneC
Default RE: MSD 6a spark plug gap and rough idle
Bouncy?
As in vac leak? Which could also give the hesitation.
ModManWC
Old Dec 7, 2007 | 08:57 PM
aim4squirrels's Avatar
aim4squirrels
Well, I idle around 600rpms hot in park. What's the standard? I thought you didn't really need to start worrying about searching for Vac leaks until you got around 750rpms hot.
HAHA Padodgeram! it's funny you mentioned TPS mod codes in the other thread. I modded this a month ago. Maybe the torx screws let loose and flipped the code on me.
Old Dec 8, 2007 | 12:12 AM
steve05ram360's Avatar
steve05ram360
go too wide on the gap and you'll have pinging problems... I'd recommend staying at .040~.045". I had issues with my 2000 5.9 motor and plug gaps tried a couple of different gaps & found that what I mentioned worked the best for the longest.
Old Dec 8, 2007 | 12:26 AM
padodgeram's Avatar
padodgeram
So your saying either stay at stock or .05 over ? kinda defeats running MSD ..
Old Dec 8, 2007 | 12:47 AM
rabbler's Avatar
rabbler
ORIGINAL: padodgeram
How do you figure that?
The purpose of the MSD system is to give you multiple sparks per cylinder vs 1
If all you wanted was to be able to run a wider spark gap you kinda wasted some money.
I bigger spark gap doesn't always mean more power/better combustion. It's just a bigger flash to light the fuel.
eg. you don't need a flame thrower to light a candle.
.040 or .045 is more than adequate for mild street application. anything bigger just increases wear &stress on the ignition components.
Old Dec 8, 2007 | 01:26 AM
steve05ram360
first thing I noticed was a smoother idle, a tad bit more power and that was running the .040 gap. I speak from my own experiences with it. stock mopar cap & rotor, autolite 3923's gapped between .04~.045"... I tried both autolite and the NGK's. the NGK's did not last that long and perofrmance was not as good as the 3923's.
Old Dec 8, 2007 | 02:39 PM
WayneC's Avatar
WayneC
"you don't need a flame thrower to light a candle."
Ooooh, man that's sweet! I'm writing that one down!
I love this place!
