i dont know what to do
Old Dec 7, 2007 | 06:19 PM
nathen361's Avatar
nathen361
Default i dont know what to do
on my 96 ram 4x4, the actuater in the front went out in it. the part is like $300 pluse getting it put on. a buddy of mine said somethin about a way to use a cable and make work like that. does anyone know what hes talkin about and how to do it?
Old Dec 7, 2007 | 06:34 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Default RE: i dont know what to do
Yea it called a posi lok. You can find them for around 100$
Old Dec 7, 2007 | 06:45 PM
nathen361's Avatar
nathen361
are they hard to install
Old Dec 7, 2007 | 10:24 PM
dhvaughan's Avatar
dhvaughan
not hard, but takes a little time and patience.
i would not spend $300+ on a new cad.
posi-lok is about $180 or so, and i really like mine, because of the ability to run 2wd low gear.
before spending a lot of money, determine what's wrong. most problems are simply broken vaccum lines under the truck. sometime its just a stuck, rusted shaft inside. there's not a lot to them.
here's how to fix them. http://www.dodgeram.org/tech/repair/..._engagment.htm
here's how to install posi-lok. https://dodgeforum.com/m_718119/tm.htm
Old Dec 8, 2007 | 05:30 PM
Socha_62's Avatar
Socha_62
Of check a junk yard.
Old Dec 8, 2007 | 05:50 PM
cnybill's Avatar
cnybill
You can build your own cable rig using parts from Ace hardware for under $30.00
Old Dec 9, 2007 | 12:41 PM
Socha_62's Avatar
Socha_62
ORIGINAL: cnybill
They work but are generally a PITA to get to work. Just my experiance with them, I've helped make 3.
They engage easily, but disengaging is hard sometimes.
Old Dec 9, 2007 | 02:52 PM
92GreenYJ's Avatar
92GreenYJ
ORIGINAL: Socha_62
ORIGINAL: cnybill
Agreed. tried doing that on my Wrangler. Not sure if this will work on the Rams as I'm not familiar with the various Ram Front Axle offerings, but on my YJs Dana 30, I was able to just completely eliminate the disconnect all together. All I did was get an axle shaft from a Cherokee Dana 30 that did not have the disconnect. picked up an extra seal that I installed in the diff, and put the one piece shaft in. haven't had a problem since and I never have to worry about the CAD not engaging. granted my 4wd light stopped working when I did that, but I know when its in 4x4 since I have lockers front and rear, I can feel the difference easily
Old Dec 9, 2007 | 07:52 PM
Socha_62's Avatar
Socha_62
Theres nothing with the same spline and legnths like there is for the Dana Turdy
Old Dec 9, 2007 | 09:08 PM
nathen361's Avatar
nathen361
where do i get the posi lok kit from?
