All set!!!
RE: All set!!!
ORIGINAL: ryans590
underdrive pullys are really good for 20HP?
ORIGINAL: greenmachine
underdrive pulleys, if you have a complete set, will give you some where around twenty hp gain. Good start for the ultimate goal.
RE: All set!!!
Reread what I wrote sorry wrong spec. Around 10 hp / 20 ft lbs tq
ORIGINAL: ryans590
RE: All set!!!
i would go with 410's. How many times in a race do you go into 3rd gear??? never. Most of the race is in 1st, then second. If anything they will help in the highend department becuase you'll get there faster. The motor wont have to work near as hard. Also Do you see alot of highway driving or mostly town. If you see mostly town then 410 will help gas milage some. If you want. you can get a set of taller tires for when your going to go on the interstate and smaller tires for the other times. Import guys do this as an easy way to get lower gearing when the go to the track
RE: All set!!!
ORIGINAL: aim4squirrels
A larger gear ratio will absolutely hurt your top end,and when you get to 117 MPH in 3rd gear in your 1/4 mile runs and start bouncing off the rev limiter, you can call me and gripe me out that you were going too slow and I convinced you to kill your top end.
RE: All set!!!
RE: All set!!!
I get better gas mileage now that I put the 4.10's in. If the bulk of your driving is under 60MPH you'll probably benefit too. Get an exact tire size and plug it into this:
http://www.drivetraindirect.com/t_gear_calculator.htm
OD ratio on our trucks is 0.69 not 1.A 1:1 ratio is your 3rd gear. You want your average diving speed to be somewhere between 1800~2000RPMs. That way your getting better power for your burn.
