oh no!
Old Dec 12, 2007 | 06:44 AM
dmdenike's Avatar
dmdenike
Default oh no!
so i ran outa gas a couple nights ago tryin to make it to the sunco :P...anyway, my check engine light came on when my truck was sputtering trying to suck fuel from the tank....after i got gas the CEL was still on. I went to auto zone and had them scan the codes...he said i had a random misfire on cyclinders 1,2, and 3. What does this mean? and What do i need to buy or fix...please help. He said since its been a while since i did a tune up maybe thats what i should do? is this true?if so what one would yall recomend?
thanks!!
Old Dec 12, 2007 | 07:30 AM
steve05ram360's Avatar
steve05ram360
Default RE: oh no!
means your cylinders were starved for fuel and it thru a code... disconnect your battery for about 5~10 minutes and it will clear the codes. it shouldnt come back unless there is a problem.
Old Dec 12, 2007 | 10:27 AM
ryans590's Avatar
ryans590
Default RE: oh no!
turn the ket to start for ~10 seconds too while the bat is disconected
Old Dec 12, 2007 | 10:30 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: oh no!
dmdenike
since ya ran on fumes from the tank, please change your fuel filter... this will save your engine from the crud you just slurped up from the bowels of the tank.[:@]
Old Dec 12, 2007 | 10:32 AM
ryans590's Avatar
ryans590
Default RE: oh no!
ORIGINAL: Kev_n_AZ
dmdenike
you cant change the filter unless you drop the tank and change the pump aswell, the filter is part of the pump, and is inside of the tank
Old Dec 12, 2007 | 12:07 PM
dmdenike's Avatar
dmdenike
Default RE: oh no!
turn it to start? you mean like try to crank it?? i just disconnected the NEG. terminal....is this what you mean by disconnecting the battery?
Old Dec 12, 2007 | 12:09 PM
arcsum68's Avatar
arcsum68
Default RE: oh no!
Yes, disconnect the battery and turn the key like you are cranking the engine.
This resets the computer.
Old Dec 12, 2007 | 12:13 PM
dmdenike's Avatar
dmdenike
Default RE: oh no!
thanks bro
Old Dec 12, 2007 | 12:18 PM
dmdenike's Avatar
dmdenike
Default RE: oh no!
ahh!!! yall are amazing...it worked...no more CEL...now ill just see if it comes back! thanks again
