Need warmer air!
Old Dec 14, 2007 | 05:36 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Need warmer air!
Poke around here and you'll see pics I posted of my heater core. It could have a couple of small leaks in it. Mine did and the truck wbarely got warm. Now, that thing roasts me with it barely into the Hot range.
Old Dec 14, 2007 | 05:51 PM
hometheaterman's Avatar
hometheaterman
He said he flushed it all out although he said it's hard to tell if it has a leak with it all apart. We did determine we think the A/C is trying to blow at the same time as the heat though.
Old Dec 14, 2007 | 11:33 PM
robles4242's Avatar
robles4242
I dont even know where my heater core is! This will take research!
Old Dec 15, 2007 | 10:14 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: robles4242
Good lord! $12-$15 for a Haynes will be money well spent. Here's the DIY for it and it's loaded with pictures.
https://dodgeforum.com/m_879602/mpage_1/key_/tm.htm
Old Jan 2, 2008 | 10:08 PM
robles4242's Avatar
robles4242
I tried to flush out my heater core and changed my coolant. NOW i have NO heat! its 9 degrees can someone help! I cant take this i have to goto work everyday!
Old Jan 3, 2008 | 11:54 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Define "tried to flush" the heater core. Either you have an air pocket or, as I previously stated, your heater core is leaking. You won't know until you pull the dash, so roll up your shirt sleeves and dig in.
Old Jan 3, 2008 | 06:24 PM
ICEMAN_CH's Avatar
ICEMAN_CH
How much will a 180 T-stat affect the heat?
Old Jan 3, 2008 | 07:14 PM
robles4242's Avatar
robles4242
Its flowing through i flushed my whole system. The coolant is nice and hot! New fresh coolant and everything. My reserve vaccum isnt holding the pressure it should but whats that effect my air being warm!?! Whats left im working on it tomorrow after work with professionals....?
Old Jan 3, 2008 | 07:26 PM
CSCustomCars's Avatar
CSCustomCars
Update for me: Got the coolant flushed and a t-stat put in. The heat improved a lot, but still isn't where it should be in my opinion for a regular cab truck. But, it's livable.
Old Jan 3, 2008 | 09:03 PM
1BigRamaniac's Avatar
1BigRamaniac
It was 9 here in Saint Peters MO too. I had to put my truck over on recirculate to get it warm inside. I just think it is pulling in such cold air that it does not have a chance to get warm. Try that. Also look at your gauge, you may need to put a piece of cardboard in front the radiator to give it a chance. That is what I might try next. BTY on the drive home, it was normal.
