what type of gears should I get?
Old 12-19-2007, 11:12 PM
You_Stroke._I_Ram.'s Avatar
You_Stroke._I_Ram.
You_Stroke._I_Ram. is offline
Default RE: what type of gears should I get?
Or better yet i think its this one
http://www.4wheelparts.com/PDT291550.aspx
My bad
Old 12-19-2007, 11:16 PM
G0tMudd's Avatar
G0tMudd
G0tMudd is offline
i plan on getting 4.56's cloest u can get to stock settings. 4.88 if u wheel ur tow alot.
G0tMudd's Avatar
G0tMudd
G0tMudd is offline
ORIGINAL: G0tMudd
i plan on getting 4.56's cloest u can get to stock settings i run 35's also.. 4.88 if u wheel ur tow alot.
Old 12-20-2007, 12:06 AM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
Most of those charts that say 4.56 are closest to stock are charts designed for the Jeep world. These trucks (especially if you have a quad cab or extended cab truck) weigh so much more, and are so much bigger, I think we need our own chart.
Old 12-20-2007, 02:19 AM
You_Stroke._I_Ram.
haha yea i just need to take all this strian off my transmision.
its currently in the shop now gettting adjusted and checked on because i recently had it rebuilt.
Old 12-20-2007, 09:11 AM
Silver_Dodge
That is definetly a good reason to do gears when going to big tires.
Old 12-21-2007, 12:26 AM
Chopper1's Avatar
Chopper1
Chopper1 is offline
I put the 4.56 gears in while I had 35's on and was it was awsome. After running around with 3.55 gears there was no comparison.
RPM's were a little higher than what it was stock, which was too low in my opinion anyway. Was able to use overdrive again, throttle response was better than new. Pulled 16' enclosed motorcycle trailer fine. You will need a new front carrier if you have 3.92 or lower gears. Don't remember which one without looking at the reciept.
http://www.drivetrainspecialists.com...44/open-1.html
Old 12-21-2007, 12:55 PM
You_Stroke._I_Ram.
alright and how much did the whole set up end up costing you?
Old 12-21-2007, 01:02 PM
Silver_Dodge
When I went from stock gears to 4.10's and a Auburn limited slip in the rear, it ran me just under $2000 for parts and install. So i'm figuring that again minus the cost of the Auburn since it will remain.
Old 12-21-2007, 01:08 PM
You_Stroke._I_Ram.
thats alot of money haha
Quick Reply: what type of gears should I get?
