shifter indicator reads off do you know how to fix this?
Old Dec 22, 2007 | 01:07 AM
johnjokela's Avatar
johnjokela
Default shifter indicator reads off do you know how to fix this?
i changed my heater core and dropped my steering wheel , i thinked it triggered something when i dropped my steering wheel,now the shift indicator reads off, for example, when i have it in 1st the indicator reads D , do you know how to correct this?
Old Dec 22, 2007 | 07:05 AM
2 Marks's Avatar
2 Marks
Default RE: shifter indicator reads off do you know how to fix this?
I have the same problem - good question
Old Dec 22, 2007 | 08:04 AM
shott8283's Avatar
shott8283
****ty design... the shift selecter and the shift indicator are connected by a stupid little cable system.. PITA .. mines been busted for a while and really not even worth fixin!
Old Dec 22, 2007 | 09:36 AM
dhvaughan's Avatar
dhvaughan
easy fix. remove the knee knocker panel under the steering wheel and look for the white plastic star wheel with the cable attached to it. you might have a cable routing problem, or you might just need to adjust the star wheel to line it back up. if you remove it, pay very close attention to the arrangement of the 2 or 3 little pieces, or else it takes some thought to get it back together right. it baffled me for a few minutes.
Old Dec 22, 2007 | 12:33 PM
johnjokela's Avatar
johnjokela
thanks for the replies at least i have good heat now,i will check the cable and see if its broke
