Will a 3rd gen radio work in a 2nd gen?
Old Nov 30, 2004 | 04:22 AM
Leonard's Avatar
Leonard
Default Will a 3rd gen radio work in a 2nd gen?
I have just noticed the new in dash 6 disc MP3 players.
Has anyone wired one up to a pre 02 model?
I know the harness is different on the 02 and later but I wonder if it would work?
Old Nov 30, 2004 | 06:41 AM
Ramtuff's Avatar
Ramtuff
Default RE: Will a 3rd gen radio work in a 2nd gen?
I'm sure you could wire it up, but you'll run into another problem...fitment. The newer radios are oval faced, and are much wider than the square faced units that fit in our trucks. It's doable though. I swapped in a 4 disk in-dash unit into my truck from a 2001 Chrysler car. Although it was plug and play, I had to do a little cutting on the dash panel. Here's a pic....as you can see, I did sort of a hack job on it, but I need to replace that panel anyway so looks weren't too important to me at the time. Once I get a new panel I do a nice job trimming it.
[IMG]local://upfiles/8683/FD5DF6EEEDC242A8A7717624A236461A.jpg[/IMG]
Old Dec 1, 2004 | 11:04 AM
tchaap's Avatar
tchaap
ramtuff - it looks pretty good. What did you use to trim th panel with?
Old Dec 1, 2004 | 12:14 PM
moparturd's Avatar
moparturd
There is a cut-off date at like 01 or 02 for compatability. I'm pretty sure it was 01 was compatable, anything after 01 won't work.
Old Dec 1, 2004 | 12:18 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
unless you already have it, or are getting it for very cheap..i wouldnt buy a dodge radio..there are alot of problems...
Old Dec 1, 2004 | 01:59 PM
moparturd's Avatar
moparturd
I've never had a problem with a stock radio in a Dodge. One thing about the stock system, it looks better in the dash.
Old Dec 1, 2004 | 02:57 PM
Ramtuff's Avatar
Ramtuff
ORIGINAL: tchaap
Thanks. I used a Dremel, but all I had was a rough stone bit for it. I need to get some good cutting and sanding bits for it.
Old Dec 1, 2004 | 03:03 PM
Ramtuff's Avatar
Ramtuff
ORIGINAL: mopartodd
I agree on both counts. I'd much rather have a factory radio in the dash than any of the new aftermarket units. I'm young, and I love music, but I don't need a radio with a rotating face, some dopey looking screen savor, or a bunch of goofy flashing lights on it. As long as it has FM and a CD player/changer, I'm happy.
I did the same thing with my 90 Ramcharger too. I replaced the factory tape player with a factory AM/FM/Cass./CD player out of a second gen Ram.
