Non AC belt on a truck with AC?
Old Dec 22, 2007 | 09:07 PM
eyebrowski's Avatar
eyebrowski
Default Non AC belt on a truck with AC?
The bearing in my AC compressor died on me while plowing today. Can I install a non-AC serpentine belt on my 00' 3/4 ton to bypass the AC compressor temporarily?
Thanks,
Greg
Old Dec 22, 2007 | 09:51 PM
greenmachine's Avatar
greenmachine
Default RE: Non AC belt on a truck with AC?
You should be able to. What you can do is take a string, preferably one with no elasticity, and follow the route the belt will take w/out the ac. Tie it off then go to the parts store and have them measure it. I have found that you normally need one just a tad longer than the string to fit properly.
Old Dec 24, 2007 | 11:17 AM
eyebrowski's Avatar
eyebrowski
The non-AC belt seems to be a couple inches too big. Is there anyway to get the tensioner to pick up the extra travel?
According to this it should work:
Old Dec 24, 2007 | 01:20 PM
pcfixerpro's Avatar
pcfixerpro
Link don't work, but if you did the string test as suggested beforeinstead of buying the non AC belt, i think you would be just about set.
Old Dec 24, 2007 | 01:51 PM
eyebrowski's Avatar
eyebrowski
Here is the link: http://www.dsmloggers.com/greg/belt.JPG
I was told by the dealer it would work so I took their word for it, excellent.
Old Dec 24, 2007 | 05:47 PM
DBG's Avatar
DBG
I went through this on my 99. I think I still have the napa belt in the shed that doesnt go around the ac. The one for the truck with no ac will be too big. I will go look in a little bit and see if it's still there and get you the part #
Old Dec 24, 2007 | 06:48 PM
Cereal Killer's Avatar
Cereal Killer
PM indy ram man if he doesn't reply to this thread by the time you read this. I'm pretty sure he got a belt that bi passes his a/c because he wanted to cut it out for his track time.
Old Dec 24, 2007 | 06:51 PM
1980blackfiveoh's Avatar
1980blackfiveoh
I ran my truck like that for two years without any problems. It did take a while to find a suitable belt. I went a little narrower (5 cog instead of6)to get the best fit.
Old Dec 25, 2007 | 12:25 PM
eyebrowski's Avatar
eyebrowski
Thanks guys, I PM'd indyramman but if anyone happens to have a P/N please let me know.
Old Dec 26, 2007 | 06:06 PM
IndyRamMan's Avatar
IndyRamMan
I bypassed the AC and PS at the same time. If you want to bypass just the AC, I believe you have to remove the compressor. If anyone has done this and wants to chime in and correct me if Im wrong, go for it.
