Wheel hop while driving?
Old Nov 8, 2016 | 12:12 PM
Sheriff420's Avatar
Sheriff420
Originally Posted by jim_r2008
I realize this is an old post but if your still experiencing this problem, I have had the same thing several times sounds like the tires are bad belt separating got better tires problem solved.
Bad tires/out of balance tires do cause wheel hop, especially at specific speeds like 48mph and 70mph.
Bad shocks may cause a slight wheel hop, especially after hitting a bump.
Briggs said that his went away for a moment when he turned to the right and that tells me that he had bad trac bar bushings because when you turn you put pressure on those bushings and they're not able to wiggle side to side. Sounds like his truck was on its way to having the butt-puckering death wobble.
