Wheel hop while driving?
Old Dec 26, 2007 | 11:08 PM
Briggs248's Avatar
Briggs248
Default Wheel hop while driving?
This doesnt happen every day but somtimes its more present. I will be driving and it seems like the truck is hopping up and down. Its really weird it did it a little bit in the begining of the summer then it stoped for a while. Now its starting to do it again. Like I said it doesnt do it all the time , id like to get it taken care of asap. I was thinking maybe a transfercase mount?
Old Dec 26, 2007 | 11:18 PM
padodgeram's Avatar
padodgeram
Default RE: Wheel hop while driving?
Mite have an axle hop .. craw under and make sure all the bolts are tight the U bolts that go around the axle , since u said transfer case ill assume you have a 4x4 on the front make sure trac bar bolts are tight shock bolts are tight shock tower bolts are tight ..
Old Dec 27, 2007 | 10:33 AM
LPIdaho's Avatar
LPIdaho
I know exactly what you're talking about!
It will happen to me everyonce and a while, especially if I'm going 35 for a while around town.
But it also doesn't happen often, once and a blue moon.
Old Dec 27, 2007 | 10:55 AM
ICEMAN_CH's Avatar
ICEMAN_CH
Can you post more information like year, model, Things you've done to it.
Old Dec 27, 2007 | 05:44 PM
grumpyoldman's Avatar
grumpyoldman
ORIGINAL: LPIdaho
Yup, same here. Every once and a while my front end feels like it's hopping at around 35-45 mph. Still haven't figured it out yet. '01 1/2 ton 4X4, with stock suspension here.
Old Dec 27, 2007 | 05:46 PM
SilverRam_01's Avatar
SilverRam_01
I got some wheel-hop one time leaving a red light with the rear tire chirping:P Is it coming from the front or the back?
Old Dec 28, 2007 | 12:40 AM
Briggs248's Avatar
Briggs248
ORIGINAL: SilverRam_01
feels like the front.... If i cut the wheel to the right it seems like it goes away for a second. Also the shifter for the 4x4 shakes from side to side. Its really weird it only shakes when the truck is hopping.
Btw I have a 1995 bone stock ram 1500 v8 with 4x4 (its my work truck) but its very realiable (knocks on wood desk)
Old Dec 28, 2007 | 01:33 AM
SilverRam_01
ORIGINAL: Briggs248
even on a smooth road? hmm.... idk, bad shocks?
Old Dec 28, 2007 | 09:32 AM
RAYZOR1234's Avatar
RAYZOR1234
are you sure its in the front? i had the same problem on my 01 1500 QC 4x4. i ended up disconnecting the emergency brake cable and it fixed the problem completely.for some reason the ebrake was catching intermittently when i would begoingover 30mph. disconnecting it was not the safest thingbut a quick fix until it warms up enoughand i can get into the drums to see whats going on with the e-brake system.
Old Nov 6, 2016 | 07:05 PM
jim_r2008's Avatar
jim_r2008
Default Wheel hopping
I realize this is an old post but if your still experiencing this problem, I have had the same thing several times sounds like the tires are bad belt separating got better tires problem solved.
