Blew my water pump im sure
Old Dec 30, 2007 | 10:53 AM
JCliffordd's Avatar
JCliffordd
Default Blew my water pump im sure
Ok last night my engine temp was around 250 and my battery went from chargering normal then dropped to around 8 and my GEN light came on
It was really late and i was just happy i was home i havent gone outside to really look yet but im almost positive i blew my water pump
Old Dec 30, 2007 | 01:00 PM
TheForce55555's Avatar
TheForce55555
Default RE: Blew my water pump im sure
see if you can wiggle the fan, If it does move that means the water pump is cooked.
Old Dec 30, 2007 | 01:28 PM
JCliffordd's Avatar
JCliffordd
it moves a little
Old Dec 30, 2007 | 01:53 PM
Jr. Mechanic's Avatar
Jr. Mechanic
ORIGINAL: TheForce55555
How does that work? the fan is on a clutch, so it spins but the water pump does not Another way to see if it blew, is to see if there is coolant every where. When my uncle's 96 blew the water pump, coolant went ALL over the engine compartment.
Old Dec 30, 2007 | 02:10 PM
JCliffordd's Avatar
JCliffordd
hahaha yeah its everywhere, i figured i blew it because that what happened to my Grand Cherokee when the water pump blew
Old Dec 30, 2007 | 02:19 PM
1BigRamaniac's Avatar
1BigRamaniac
Take the cap off your radiator. When the truck gets warm (thermostat)you will see the flow. Jr. Mechanic is right, there is a weep hole, on the bottom. Once mine spewed water out that hole, once it did not.
Don't worry, you can get those engines really hot and you won't ruin them. Mine got so hot it blew a heater hose in the garage. No engine damage. My radiator failed, but you could turn on the heater to draw off some of the heat. The temp went down when driven, up when at a light.
Good luck!!
Old Dec 30, 2007 | 02:32 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: 1BigRamaniac
Good luck!!
That's no lie. The high nickel content of the Dodge blocks prevents damage when the engine is run too hot. I've had mine damn near pegged and nada. Still runs like a champ.
Old Dec 31, 2007 | 01:41 AM
Jr. Mechanic
Cant kill an LA series engine.
Old Dec 31, 2007 | 11:35 AM
TheForce55555
It works i Do it all the time to check for bad water pumps, you have to shake it to see if the bearing is bad in the water pump
