Who knows the transmision really well
Old Jan 3, 2008 | 12:34 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Default RE: Who knows the transmision really well
I'll rebuild it for ya. That way I can get practice before I do mine. [sm=badbadbad.gif]
Old Jan 3, 2008 | 12:38 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: ICEMAN_CH
I'd volunteer for that like I'd volunteer for a kick to the crotch
Old Jan 3, 2008 | 12:40 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Wow, your into some freaky **** man.
Old Jan 3, 2008 | 01:07 PM
greenmachine's Avatar
greenmachine
You can adjust the tranny at the throttle body also.
Passenger side of the throttle body towards the back there is a linkage. You have to release the clip and adjust the slider then lock it back into place. You may do this a few times to get it exactly where you like it. The only thing you need to watch is the second third gear overlap. Good luck.
Old Jan 3, 2008 | 01:11 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: greenmachine
That is to adjust the slack for the TV cable, which should have about a maximum of 1mm of play, correct? That's not going to affect the 2-3 shift if the bands aren't adjusted properly.
Old Jan 3, 2008 | 01:19 PM
greenmachine
ORIGINAL: VWandDodge
I believe that is the other cable. There are two on that same bracket,the one you wantis the outboard. According to the Mopar guy, whom I spoke with yesterday, said he did not like the way it was shifting and told me I could do that adjustment to my liking.
Old Jan 3, 2008 | 01:35 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
That's the TV cable. It adjusts the upshift but is not going to correct issues with mis-adjusted bands.
Old Jan 3, 2008 | 02:33 PM
greenmachine
K
Old Jan 4, 2008 | 12:37 AM
rockwood84's Avatar
rockwood84
mine shifts in 2nd at 2500 rpms at 25 mph 3rd at 3100 rpms at 40-45 mph and 4th at 2500 rpms at 55-60 mph holding throttle steady. w/o throttle 2nd shifts at 30mph at 2800rpms 3rd shifts at 3500 at 50mph and 4thshifts at 60 at 2500 rpms
Old Jan 4, 2008 | 05:30 PM
master tech's Avatar
master tech
Site Moderator & Tech
If your transmission is shifting into 3rd at 50 mph, then the seals are hard in the front drum and is causing your shifting problem. No adjustments will fix this problem, time for a seal kit and clutches if needed.
