need help truck died
Old Jan 4, 2008 | 01:18 PM
CALVIN305's Avatar
CALVIN305
Default RE: need help truck died
what did it end up being for you?
the comp reset? i hope it isnt the pump [&:]
Old Jan 4, 2008 | 01:27 PM
padodgeram's Avatar
padodgeram
This is why i hate guessing , 5 people can have the same issue 4 will be different reason.. dont worry about it till you get the OH -**** -READER...
Old Jan 4, 2008 | 01:38 PM
CALVIN305's Avatar
CALVIN305
lol will do
Old Jan 4, 2008 | 02:24 PM
CALVIN305's Avatar
CALVIN305
still waiting for the wife.. but in the meanwhile i disconnected the TPS and it started good but the rpm's at idle was at 1k.. higher then normal. then i plugged it back in and it stayed at 1k so i dont know what that means. i disconnected the MAP sensor and the rpm's kept going from 200 and going to 1000 back and forth.
just updating.
Old Jan 4, 2008 | 04:12 PM
CALVIN305's Avatar
CALVIN305
looks like im going to have to do this in the morning. my wife has a loaner car from lexus because her 2002 lexus rx300's tranny just crapped out on us so its at lexus right now getting a new tranny and its ready so they want the loaner back. so we have to go now to return it. meanwhile after a new transmission(which a extended warrenty paid for thank god) the guy says she needs a full brake job which is going to be $1100 that the warrenty doesnt cover!... if i do it its $200 in parts. so yea guess which we are going to do...
anyway ill post back in the morning after i get the reader.
Old Jan 4, 2008 | 05:23 PM
master tech's Avatar
master tech
Site Moderator & Tech
You need to start by pulling codes out 1st and then go after the problem.
Old Jan 4, 2008 | 06:15 PM
Tarner's Avatar
Tarner
Mine does the same thing. My mechanic told me to clean the IAC, throttle body, and the recess the the IAC sensor threads or goes into. I have'nt done this yet to see if it fixes it. But this weekend I will since it's going to be warm outside. What I do to make the truck run when it won't idleis rev the motor to about 3,000 RPM when I start it. The RPM's come don't and then the truck Idles fine.
Old Jan 5, 2008 | 12:42 PM
CALVIN305's Avatar
CALVIN305
4 codes pulled
p0505 IAC malfunction
p0123 TPS volts high
p0108 MAP volts high
p0133 o2 bank 1 sensor 1 low volts
it cant be all 4 sensors can it??
i started the truck when i got here and it started fine. but idled at 1k. then i ran the code reader erased the codes. 10min. later i started it but it wouldnt start it died. so i took the iac sensor off and started it and it would go to 500 then drop to 200 then die.
any ideas?
Old Jan 5, 2008 | 11:33 PM
CALVIN305's Avatar
CALVIN305
well i started to take off the IAC but one of the screws is stripped. so i took the whole throttle body off so its easier to work on. of course something else broke as i was taken the TB off. one of the linkage plastic broke. hopefully its a easy fix.
anyway do you guys think its the IAC? or all 3 sensors?
Old Jan 6, 2008 | 12:07 AM
dodgeypete's Avatar
dodgeypete
My 97 did the same thing right before the fuel pump died......
