Unknown Origin of Squeak
Old Jan 9, 2008 | 04:01 PM
MagnumVP's Avatar
MagnumVP
Default Unknown Origin of Squeak
I hear a squeak when my truck is in motion. It sounds like it is coming from the front (when I stick my head out the window). It isn't the brakes I check those and the sound doesn't increase or decrease when I stop. No squeak when stopped, just when in motion. I am guessing maybe something on the front axle but not sure. It is tough for me to get under the truck when it is in motion. It isn't very loud but you can diffidently hear it. Any ideas of what it could be?
Old Jan 9, 2008 | 04:02 PM
SilverRam_01's Avatar
SilverRam_01
Default RE: Unknown Origin of Squeak
I'm getting a sqeuak from mine, it sounds like they same thing as you, but I'm 2wd, Im thinking mine might be a wheel bearing that started sqeuaking after driving through floodwater.
Old Jan 9, 2008 | 04:10 PM
MagnumVP's Avatar
MagnumVP
Well it defidently could be the wheel bearings. I just recently noticed it and I'm sure somewhere I ran through some water puddles in the 2 weeks that we have had rain. I'll need to find out if it is coming from both sides or just the one. Hope changing those isn't too involved.
Old Jan 9, 2008 | 06:15 PM
Ram2K1's Avatar
Ram2K1
This may help:
https://dodgeforum.com/m_1023845/tm.htm
Mine was driving me nuts until I went crazy with a can of white lithium grease. I think it was the shift lever on the tranny. If it don't work for you...your only out a couple of bucks!
Old Jan 10, 2008 | 12:04 AM
dhvaughan's Avatar
dhvaughan
transmission linkage bushings. front axle u-joints. front drive shaft u-joints. front wheel bearings.
Old Jan 10, 2008 | 03:01 AM
Cowgirl4christ's Avatar
Cowgirl4christ
Mine is/was squeakin like CRAZY! Turns out it was the inner and outer tie rod ends along with the upper and lower ball joints. $500 bucks altogether to replace!![:'(]
Old Jan 10, 2008 | 05:57 PM
MagnumVP's Avatar
MagnumVP
I'll look into all of them. Starting with the cheapest and working from there. Thanks for all the advice.
Old Jan 10, 2008 | 06:32 PM
TheForce55555's Avatar
TheForce55555
Sometimes i wish i could strap myself to the front end of the truck, while someone else drives it. To find all the weird noises mine makes sometimes. I replaced all the stuff that was really wore out, but im tired of throwin money into that crappy coil over design
Old Jan 10, 2008 | 06:49 PM
MagnumVP's Avatar
MagnumVP
I'm just hoping that the queak that I hear is coming just from the left side and not from the way under where it could be something more. I hope it resides in the tire/wheel area. Fingers crossed while I hope I can get to it sometime this weekend.
Old Jan 10, 2008 | 10:17 PM
TheForce55555
GOod luck, you will need it
