MSD 6AL in a 1996 5.2?
Old Jan 10, 2008 | 09:52 PM
CPTAFW163's Avatar
CPTAFW163
Default MSD 6AL in a 1996 5.2?
I still have the setup that I had in my old camaro with the blaster 2. Can I put that into my 1996 5.2? I have a hypertech coil in it already, but it would be cool to have the module in it too.
Thanks
Old Jan 10, 2008 | 09:56 PM
padodgeram's Avatar
padodgeram
Default RE: MSD 6AL in a 1996 5.2?
So you want to run the 6al with the blaster coil ?? or just the coil ?? either way you can do it..
Old Jan 10, 2008 | 09:57 PM
CPTAFW163's Avatar
CPTAFW163
The whole thing, how did you do it? If you could help it would be much appreciated
Old Jan 10, 2008 | 10:03 PM
CPTAFW163's Avatar
CPTAFW163
I actually just bought the hypertech coil today and haven't installed it. The blaster didn't look like it could be compatible. I am also thinking of a throttle body upgrade, spacer,and the fitch fuel catalyst.
BTW, how is your tranny holding up. Mine was replaced at 72,000 and its at 143,000 right now...i am getting worried.
Old Jan 10, 2008 | 10:19 PM
padodgeram's Avatar
padodgeram
you gotta cut the stock ignition , your grean/orange wire hooks up to the red wire on the box 6al , white wire from the box hooks up to the black/grey on your ignition , from the box to the coil , orange connects to orange/green , black connects to black and grey
Knock on wood ..trans is doing ok at 129 grand...
Old Jan 10, 2008 | 10:27 PM
CPTAFW163's Avatar
CPTAFW163
I am gonna try that tomorrow.
The connector that goes to the stock coil made me think it wouldn't be compatible.
Old Jan 10, 2008 | 10:32 PM
padodgeram's Avatar
padodgeram
here is a copy , put you need PDF to view it..
http://www.msdignition.com/pdf/6%20series/6series.pdf
gotta scroll down still you see how a dodge hooks up..
This how i have mine set up using it off the box , i can either hook it up to the ss blaster or the stock replacement blaster coil.. give me 15 min.. ill take a pick of the stock replacemnet blaster..
Old Jan 10, 2008 | 10:45 PM
CPTAFW163's Avatar
CPTAFW163
I don't think i can use my blaster 2 coil (GM) but i have the hypertech coil, so that should do the trick.All hi perf coils shouldhave aroundthe same voltage curve.
Thanks for the info.
--Dan
