11 MPG To 16 MPG
Subscribe
Jan 11, 2008 | 05:25 PM
I've filled up my tank twice since I fixed my idle problem and my gas mileage went up from barely getting 11 mpg up to just over 16 mpg. I couldn't believe it. I thought I forgot to rest the trip gage the first time. But the second time I did the math twice and was like Wooo Whooo!! That's money in the bank!!!! All I did was clean the Throtle body, IAC and replace the upstream O2 sensor.
Reply 0
Jan 11, 2008 | 05:34 PM
RE: 11 MPG To 16 MPG
must be nice, glad to here someones truck is running correctly
Reply 0
Jan 11, 2008 | 06:50 PM
I wonder if just the O2 sensor alone was the reason for the better overall MPG?
Not sure what the IAC does once you start to drive, but I know the O2 sensor controls the fuel mixture... right?
Did you clean your TB while it was still bolted, or removed?
hmmm, I am ready to go from 11 to 16MPG anytime. My upstream O2 sensor looks rather rusted on, how bad was it to get it off?
Sorry for all the questions, but getting almost 50% more MPG is FANTASTIC, I hope I can get something close to the same results replacing my O2.
Reply 0
Jan 11, 2008 | 08:20 PM
Well, when I replaced my up-stream o2 sensor, the hard part was getting the damn wrench on it. After I got the wrench on it to stay, a couple good shoves, and it came right out. It's my understanding that there is some type of anti-sieze on the threads.There was on the new Bosch one I bought.
All in all, when you get the wrench on it, it should come out pretty easily...
Good luck.
Reply 0
Jan 11, 2008 | 08:28 PM
Yeah I'm thinking that the O2 is the main reason for the improvement. I still had the original O2 sensor on it and with 160,000 mile I'm sure it was time to replace it. I took the TB, and IAC off when I cleaned them and made sure everything was clean. Mine was real dirty. This is what stopped the idle problem when my truck would die after a warm start up. The IAC was stuck and it wasn't closing or opening up all the way. I also reset the PCM when I cleaned the TB and IAC. That also could of had something to do with the idle problem going away. My MPG isn't as good as it was when I bought the truck but it's close. It use to get 17-18 MPG on the Highway which is 90 percent of my driving.
Reply 0
Jan 11, 2008 | 08:31 PM
Oh yeah, the O2 came out with no problem. But I have a custom exhaust on my truck and the O2 is easier to get at then stock.
Reply 0
Jan 12, 2008 | 12:13 AM
Quote:
ORIGINAL: Tarner
160K??? you're supposed to change them every 80K max. Just think of all the extra dead baby dinosaurs you burned up.
Reply 0
Jan 12, 2008 | 03:53 PM
Hell think about all the dead presidents I threw away
Reply 0
Jan 12, 2008 | 04:30 PM
hell im at like almost 115k on stock oxygen sensors
Reply 0
Jan 12, 2008 | 04:31 PM
WHAT IS THE IAC?
THANKS
Reply 0
