new mwmber help
Old Jan 12, 2008 | 04:21 PM
frenchhornthorne's Avatar
frenchhornthorne
Default new mwmber help
hey just signed up I saw the advice given when some one had a problem and I need some for myself. my 95 ram 1500 5.2 is having oil pressure problems. this week I have changed the oil and filter due to oil pressure droping all the sudden. no good still had problems.I have also changed the oil pump and cleaned out the pan and pick up tube. I am still having the problem I will be driving along and the oil pressure will drop out and stay out. any help will be use full
Old Jan 12, 2008 | 05:07 PM
ozyran's Avatar
ozyran
Default RE: new mwmber help
Have you tried checking the oil pressure sending unit? It may be crapping out on you.
Old Jan 12, 2008 | 05:11 PM
TheForce55555's Avatar
TheForce55555
Yes replace the oil pressure sening unit , if it didnt have oil pressure u probly would have blowed it up by now
Old Jan 12, 2008 | 07:47 PM
jmsfulton's Avatar
jmsfulton
try changing out the sending unit. that if the motor is not knocking along with the presure drop. Chance are the sending unit failed or is failing. I had one go on a road trio aqnd like to S!@# when I seen the presure drop to zero at 70 mph. Turned out to be the sending unit.
Old Jan 15, 2008 | 01:51 PM
frenchhornthorne
hey my pressure drop occurs with ticking. the pressure drops only after I have driven some and the engine is starting to warm-up. but the longer i drive the pressure drops off quicker and stays out longer after i come to a stop and let the engine idle until I have no pressure at all.
Old Jan 15, 2008 | 03:15 PM
TheForce55555
DId you put a new sending unit in it???
