two questions
Old Jan 15, 2008 | 07:29 AM
tothewall's Avatar
tothewall
Default RE: two questions
UPDATE:
Lowered the tires to 45#. Night and Day!
Thanks for all your input guys.
Old Jan 15, 2008 | 08:41 AM
IndyRamMan's Avatar
IndyRamMan
No need to run that psi without a trailer. pump it up and down according to load.
Old Jan 15, 2008 | 08:53 AM
tothewall's Avatar
tothewall
So you are saying that 45 is too high?
Old Jan 15, 2008 | 11:37 AM
cnorris's Avatar
cnorris
Your truck wanting to move left is prob. not the alignment----its probably caster. Has the truck ever been in an accident? For an explanation of caster:
http://www.familycar.com/Alignment.htm
Old Jan 15, 2008 | 12:03 PM
dodgeman22's Avatar
dodgeman22
i run 35 psi on my load E tires i got geolander A/T-S it rides ok, when ever you put a load on fill them up
overs ram's Avatar
overs ram
Have you checked the track bar for play? If there is a crownin the road and bad track bar it could pull, track bar issues show up mostly in wandering/playand possible death wobble but its worth a check (you need two people to check)
on tire psi, when I had stock E tires on my 4x4 2500 ram I would run 35-40 unloaded around town, sometimes even lower for comfort, on long trips unloaded (for better MPG I would be closer to 45psi) when loaded with jeep on trailer I would go to max on sidewall 65psi i think
now with my 315/70/17 load range D's I run around 33psi around town unloaded
