GEN???
Old Jan 15, 2008 | 12:43 PM
IndyRamMan's Avatar
IndyRamMan
Default GEN???
My generator light is comming on, The truck isnt showing more than the first white mark on the volt guage. The alternator is correctly hooked up, there isnt any corrosion on the batt, It starts on the batt, but very sluggishly. There are two things im thinking at this point...dead batt, and the other the ground for the alternator (that wire that bolts to the accessory bracket) i painted the bolt that its on....maybe its not getting a ground through that? The truck stays running when it is running though, and the volts dont go down when its idling, but slightly when im driving. Whats up?
just checked, its definately running off the batt...so its the alt. Im thinking im just gonna pull it and go get it tested.
Old Jan 15, 2008 | 01:06 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Default RE: GEN???
You have to scrape that paint off for the ground.
Old Jan 15, 2008 | 01:29 PM
padodgeram's Avatar
padodgeram
Default RE: GEN???
its the BIG CAM drawing all the juice out of it... clean that ground wire ..You know better...if that does not work then go have it tested...
Old Jan 15, 2008 | 02:08 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: GEN???
yea, cleaned the ground and went to start and batt had lost too much juice, so i need to charge that. WHile im at it i pulled the alt and im gonna test it for ****s. you are right about the cam drawing more juice. If it idles low it pulls a lot more power from the batt
Old Jan 15, 2008 | 04:48 PM
tazman6789's Avatar
tazman6789
Default RE: GEN???
u can have the alt tested while its on ur truck. They make a tool to hook to ur alt while its running to show how much power its putting out. Autozone or advanced may test it for free in the parking lot. Some small shops will do it for free too.
Old Jan 15, 2008 | 06:50 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: GEN???
Yea F*** advance auto. That a$$hole tested my alt and said it was dead, so I took his word on it and spent $130 on a new (reman) one. At this point im ready to barf. I NEVER put reman **** on my truck, and I RARELY buy from crapstores like advance and all them. So they said my batt was dead too...ok fine. I went back to the store I bought my batt at and said its dead id like a new one....they charged it and its good. Guess what else was good? yea, $130 because some punk a$$ wanted to make himself feel like a big man and try to impress someone when he couldnt read the friggin tester. It was the damn buss fuse in the black box. $2.37. Apparently they dont make FDL style fuses anymore in 100+ amp (atleast no one sells them) so I had to modify a diffrent fuse to fit, and it charges just fine now... [:@]
Old Jan 15, 2008 | 06:55 PM
TheForce55555's Avatar
TheForce55555
Default RE: GEN???
What else is new. people get screwed by Advance, Auto zone, etc Everyday. I would never let them touch my vehicle. I bought new windshield wipers there one time and the dumbass that worked there couldnt even change them
Old Jan 15, 2008 | 07:05 PM
padodgeram's Avatar
padodgeram
Default RE: GEN???
ORIGINAL: TheForce55555
why would you want them to change your wipers ?? unless you couldnt
