fuel injector leak
Old Jan 21, 2008 | 02:12 PM
Dtruck96's Avatar
Dtruck96
Default fuel injector leak
Well I just got done fixing my plenum and I was putting everything back together when I noticed that when I would turn my key to the on position to let my fuel pump pressurize my system, two of my injectors were leaking. During the tear down I did not take them out. They are leaking at the top by the fuel rail. I took one out, cleaned it real good checked the o-ring which was still good andput the injector back, making sure it was seated right and put the retaining clip back. But it still leaks. Any suggestions? Should I replace the o-rings even if they werent damaged? I brought them in the house for a little bit to warm them up thinking it would make the rings softer but it didnt help either.
Old Jan 21, 2008 | 02:14 PM
98ram5.9's Avatar
98ram5.9
Default RE: fuel injector leak
i say replace them. better then fighting problems down the line.
Old Jan 21, 2008 | 02:36 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
O-rings are cheap. I would recommend you replace all 16 of them. Be sure to lightly coat them with oil when you install them on the injector to prevent tearing.
Old Jan 22, 2008 | 06:14 PM
Dtruck96's Avatar
Dtruck96
Well I was able to fix my own problem. I put the injectors back in and put my heat gun on low and put it on them for about 20 seconds. I guess it helped seal the O-rings pretty good. It was about 30 degrees outside while I was doing this. Then I let them cool down for a couple min and started it up and no problems. thanks for the help.
Old Jan 22, 2008 | 06:19 PM
Jr. Mechanic's Avatar
Jr. Mechanic
It will start leaking again.
Old Jan 22, 2008 | 07:54 PM
jperkins812's Avatar
jperkins812
The fuel system is the last thing you want to cut corners on, because only bad things will happen.
Old Jan 22, 2008 | 10:16 PM
turkeyhunter1962's Avatar
turkeyhunter1962
Bad things is right. I didn't have my o-rings go out, but my cross-over line between the rails developed a leak. 1 fire and over $2000 in repairs later my truck did get back on the road. Took a bit to fix all ofthe problems, but it's been running good for about 2 years.
Never try to save a penney when it comes to engine fluids. You are only inviting trouble. I replace my o-rings everytime I pull the rail.
Old Jan 22, 2008 | 11:00 PM
highlander73's Avatar
highlander73
Heat gun on the fuel rails? [:-]
Old Jan 23, 2008 | 04:05 PM
Dtruck96's Avatar
Dtruck96
I fully intend on replacing the o-rings however it is kinda hard to get to the parts store to get them if your truck doesnt run. But since it does now I have purchased the new rings and they will be going in tonight. And I know you all had pictures of Fire Marshall Bill in your head as soon as I mentioned heat gun and fuel rails in the same sentence. However it worked for the time being. Thanks for all the concern.
