OIL CONSUMPTION: Bad Intake Manifold Plenum
Old Dec 9, 2004 | 09:11 PM
delphinos's Avatar
delphinos
Default OIL CONSUMPTION: Bad Intake Manifold Plenum
This has been a recurrent problem on my Dodge RAM 1500 truck. As I write this, Jack Carroll's Lynnwood Dodge in Lynnwood, WA is repairing this problem for $800. They or Chrysler paid the first time because it was just over the warranty period. 45kmiles later, same problem. Dodge Customer Service refuses to acknowledge that there is a design flaw. If your truck is consuming oil, and there is no oil on the floor, good chance that it is leaking into the manifold. I went through 4 quarts in two months. Engine may also have a spark/knock. Refere to technical service bulletin 09-05-00. You can access at the following web address..
http://dodgeram.info/tsb/2000/09-05-00.htm
Old Dec 9, 2004 | 09:26 PM
steve05ram360's Avatar
steve05ram360
Default RE: OIL CONSUMPTION: Bad Intake Manifold Plenum
APS precision or Hughs engines has a kit to solve this problem... aluminum belly pan kit for under $100 bux
