Kegger mod
Old Jan 28, 2008 | 10:25 AM
greenmachine's Avatar
greenmachine
Default RE: Kegger mod
ORIGINAL: IndyRamMan
ORIGINAL: HankL
MPI manifold without any plenum plate/gasket/bolts
seems a better way to go
for higher rpm power gains
http://www.steigerperformance.com/benefits/
yep. the m1 is very agressive for a stock motor though, even a little too agressive for me.
Indy you and I have had this conversation before about the M1. If you dont do some work you lose your bottom. No thanks until its a 409
Old Jan 28, 2008 | 11:34 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: greenmachine
ORIGINAL: HankL
that we did.
Old Jan 28, 2008 | 12:37 PM
Silver_Dodge's Avatar
Silver_Dodge
Below are a couple quotes from a very well know and respected Mopar performance engine builder in some recent email discussions I had with him on the topic of M1's. No offense to anyone on this forum, be he knows so much more about this then any of you, I tend to beleive him over anyone else. I've had lots of discussions with him on this topic, and others, and I find his information to be dead on with real life (versus stuff you hear on the forums). I'll be getting an M1 later this year, just to many other mods in the works right now to take care of first (gears for example). I do plan to mod my kegger anyway (while i'm fixing my plenum), but that is more for experimentation then anything else. I need to fix the plenum for now until it it time to do the M1, so modding the kegger will allow me to test for myself what you read about on these forums.
"What you hear online is - Oh, your going to lose your low end torque and other crap. Those are the clowns you want to race. With proper converter, gearing, engine mods, this M1 comes together well."
"The misconception is that you are losing low end. It's all over the net and I like to race those types. They concentrate on first gear and i pass them as soon as they shift because they have no clue how to properly utilize the additional HP. You are creating more HP like the old days, but the HP is spread across the entire powerband and goes up higher then you can reach in today's PCM equipped engines. The way to bring this power back down is to gear the truck accordingly."
Old Jan 28, 2008 | 01:55 PM
padodgeram's Avatar
padodgeram
ORIGINAL: Silver_Dodge
hmmm , after reading the dyno numbers on that site , im more then likely go that route with the M 1 , alot of this is common sense which alot of forums are missing... i agree with silver..and im still on a learn curve with the magnum motor
Old Jan 28, 2008 | 06:46 PM
IndyRamMan's Avatar
IndyRamMan
Thats a beautiful find, andhe is 100% accurate....the one thing you are totaly forgetting is that we dont live our lives at wot. Sometimes its worth it tonot take advantage of the top end in a DAILY DRIVER application. That is exactly why I didnt get one.You also better be reving that sobover 5500 to take good advantage over a cut keger. (shifting at 5k bringing you back down to 3900 definately isnt the optimum opperating range for the M1) Yes with gears and converter and all that it will make for a decent low end. No matter how much you buff your drivetrain your motor still is going to be reving a little higher to get going (reguardless of the ability to rev quicker from gears and a stall) Im getting 10mpg now, Id rather not spin another 200, 300, 500, however higher id haveto just to get going. I understand there is less effort exerted by the motor to get it moving with gears and a converter, but in the end you are still using more rpms to get going. When I start going a little more radical, no doubt Ill grab that M1 in a second, but for now...its a tad overkill for my mileage.
Old Jan 28, 2008 | 09:53 PM
dsertdog56's Avatar
dsertdog56
I was hoping to find said engine builders article on the internet, and either it wasn't Hughes or KRC, or I missed something scouring thier sites.
I did find one comment in a write up from KRC about 408 strokers. The last sentence suggested that for horsepower use the M-1 intake, and for torque...which is needed in any vehicle over 3800 lbs...well, they didn't say.
Hughes does state that generally one must design a vehicle around a combination of parts from pulley to differential cover. Using a poor combination or mismatchof pieces will generally make things worse rather than better. In days of yore, mismatches were generally over carbing/over camming a motor and under gearing. Maybe it's not noticable today, but it was noticable back then. ...but I degress.
The fact is that the M-1 makes power. Where it makes that powercan be the downfall of a motor and drive train of mismatched pieces. So I agree with your builder, nothing flows better above 3 grand then an M-1. And if you have the proper cam, and torque improvers like a hi stall converter and propergears, you'll be fine.
What you will have to deal with is a ride that becomes a bit "touchy". I can't describe how that feels, but only that the fun factor seems to slowlyfade.You'll have to experience that yourself and decide if those occasional and rare bursts of WOT are worth it.
I'd really like to see more guys dig into thier factorykegger and and pull out some more mid range torque and hp for street use. There's plenty to be gained by modding what the factory gave you.
Old Jan 29, 2008 | 12:50 AM
IndyRamMan's Avatar
IndyRamMan
Couldnta said it better myself
Old Jan 29, 2008 | 09:55 AM
Ram2K1's Avatar
Ram2K1
I was looking at getting a different manifold, too. I wanted to save up and fix the plenum, get the Fastman, and do the manifold, then get me a Hypertech. With that being said, is the M1 the only one that takes away the need for the plenum plate? I definitely don't have the tools to go modding the kegger, nor do I want to pay someone to do it. I really don't HAVE to do either I guess. I really just want the truck to perform where it should have from the factory. I have no desire to race or do off-roading, etc. I just want the truck to drive well and have the hp/tq to easily pull a boat or a couple quads... Is there even a need for a new manifold in this sense??? Also, this is off topic, but if I buy the kit to fix the plenum is it going to last for the life of the truck?
Thanks guys (don't mean to thread jack here)
Old Jan 29, 2008 | 09:57 AM
IndyRamMan's Avatar
IndyRamMan
I wouldnt think you would want one. Aside from not worrying about the plenum, I wouldnt want it for that application. (fix the plenum once it should be good for a long time)
Old Jan 29, 2008 | 10:08 AM
Ram2K1's Avatar
Ram2K1
Thanks... So the M1 is the only one out there with no plenum... Figures[:@]
